Old 07-24-2013, 04:26 PM   #1
swift996
swift996's Avatar
Overpipe with sway bar clearance?
Wondering if anyone can confirm running any of these over pipe options with a larger front sway bar? I'm running a 25.4mm Hotchkis front sway bar.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-25-2013, 11:47 AM   #2
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I'd like an accurate answer to this as well, but it seems like nearly every aftermarket overpipe has clearance issues with the subframe and/or bigger sways without stiffer engine mounts or grinding down the subframe to allow clearance under load.
Stock overpipe seems like the best bet for a while until the aftermarket figures out how to make them with clearance considering drivetrain movement under load with the stock mounts.
Old 07-25-2013, 12:25 PM   #3
xxscaxx
Drives: 2013 SWP BRZ
Isn't there minimal gains anyways with an overpipe? I'm doing the same though, leaving the stock overpipe and changing everything else.
xxscaxx is offline   Reply With Quote
Old 07-25-2013, 12:25 PM   #4
chutrain
chutrain's Avatar
Drives: WRB BRZ
I have the Hotchkis bar and the overpipe (Motiv) hits the swaybar. I had to use some wide washers to lower the swaybar mounts down slightly to clear. No issues so far.
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
Old 07-25-2013, 12:37 PM   #5
leon78
leon78's Avatar
Drives: 13 Whiteout
Subbed for no fuss overpipe info.
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Old 07-25-2013, 12:50 PM   #6
ft86me
ft86me's Avatar
Drives: 2013 FRS
I have the cusco sway bar. Wonder if there will be issues there. Any input? Planning on getting the Perrin overpipe
ft86me is offline   Reply With Quote
Old 07-25-2013, 01:02 PM   #7
ft86me
ft86me's Avatar
Drives: 2013 FRS
Do overpipes usually have an issue?
Old 07-25-2013, 01:46 PM   #8
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
Nameless over/frontpipe combo with Hotchkis front and rear Sway bars
It's hard to tell if it's just the road or the overpipe hitting. So far, if it does, it's not frequent enough but i'll have to check.
Books is offline   Reply With Quote
Old 07-25-2013, 01:54 PM   #9
FastLane1000
FastLane1000's Avatar
Drives: White FR-S, 6M
I'm running the hotchkis sway bar kit and motiv overpipe with plenty of clearance.
EDIT: the more I think about it... I have a slight raspiness/vibration under load sometimes that may in fact be the overpipe hitting but I had this before the hotchkis sway bar as well. I need to get back under the car and take a look. I'm going to look into it further and see if there is a suitable place for a torque strap.
FastLane1000 is offline   Reply With Quote
Old 07-25-2013, 01:59 PM   #10
chutrain
chutrain's Avatar
Drives: WRB BRZ
Mine was definitely the overpipe hitting the sway bar. I could see some of the paint missing on the swaybar and small mark on the overpipe. I only really hear it when it I give it a good takeoff in first or hard run in second, but it still annoyed me.
I had contacted Motiv and they mentioned that they only tested with the factory swaybar and not with a thicker aftermarket. I suspect that most companies did not test with a thicker aftermarket bar, therefore could be a hit or miss for many.
In the garage:
1988 BMW E30 M3
Old 07-25-2013, 02:02 PM   #11
chutrain
chutrain's Avatar
Drives: WRB BRZ
Motiv does great work with their products, so I do not fault them. Everything bolted up nicely. It could be variances in the cars themselves, something that I have seen before. I had maybe less than a quarter of an inch between bar and pipe.
In the garage:
1988 BMW E30 M3
Old 07-25-2013, 02:24 PM   #12
swift996
swift996's Avatar
Yeah most of these parts are designed with everything stock in mind. I've ran into quite a few snags where a design didn't have other aftermarket parts factored in. The product of such a new platform!
Old 07-29-2013, 01:50 PM   #13
swift996
swift996's Avatar
Anyone running a Perin over-pipe?
Old 07-29-2013, 02:00 PM   #14
wawro569
Drives: 2013 Scion FR-S MT
Nameless OP/DP combo here reporting no issues what so ever.
wawro569 is offline   Reply With Quote
Wheel Directory: Forgestar F14 18x9.5 +38 empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 12-26-2014 05:24 AM
Motiv Concepts Overpipe + HFC, Overpipe + Test Pipe Specials! MotivConcepts Engine, Exhaust, Bolt-Ons 96 07-19-2013 02:03 AM
Body Kit with the most clearance? Sambo FRS Cosmetic Modification (Interior/Exterior/Lighting) 7 06-20-2013 01:47 PM
Driveway Clearance? topazsparrow Scion FR-S / Toyota 86 GT86 General Forum 17 06-14-2013 11:37 AM
BRZ front clearance a2cpc BRZ First-Gen (2012+) — General Topics 14 01-23-2013 07:38 AM
