Old 05-17-2015, 11:23 AM   #1
merino_frs
merino_frs's Avatar
Alignment after LCA install
Last night I installed the Buddy Club LCA. Pretty easy install. So after it was done I noticed that my toe was way off. I understand that I need to get an alignment next but is it normal for the toe be really off? (Before the LCA install, alignment want dead on" appreciate the feedback fellas.
merino_frs is offline   Reply With Quote
Old 05-17-2015, 11:39 AM   #2
cnk
Drives: '13 DGM BRZ Limited
Toe and camber are tied together in the rear. Both have to be adjusted at the same time during an alignment. If it was good prior, they should be able to set camber back to what it was and toe will come back to the previous setting.
cnk is offline   Reply With Quote
The Following User Says Thank You to cnk For This Useful Post:
merino_frs (05-17-2015)
Old 05-17-2015, 12:46 PM   #3
merino_frs
merino_frs's Avatar
Ah i see. Do you think it would be necessary to buy adjustable toe links? Or is that an overkill for a daily?
Old 05-17-2015, 12:47 PM   #4
gramicci101
Off Topic
It shouldn't. How low are you going?
Old 05-17-2015, 02:15 PM   #5
merino_frs
merino_frs's Avatar
I'm on a 4" drop
Old 05-17-2015, 02:23 PM   #6
gramicci101
Off Topic
Originally Posted by merino_frs View Post
I'm on a 4" drop
A 4" drop? Are you on airbags or something?
You probably will need toe arms. If your ride height is adjustable on the fly (bags), have the toe set properly for your driving height and don't worry about the rest.
Old 05-17-2015, 02:43 PM   #7
merino_frs
merino_frs's Avatar
Well my coils are set to a 3" drop, my LCA lowers the rear an additional 20mm
Old 05-17-2015, 03:58 PM   #8
gramicci101
Off Topic
You already had the coils at a 3" drop before installing the LCA and things were fine? In that case, give it a try without new toe arms. Right now the LCA is probably way way off and that's messing the toe up.
The Following User Says Thank You to gramicci101 For This Useful Post:
Old 05-17-2015, 04:44 PM   #9
merino_frs
merino_frs's Avatar
As soon as I threw on the LCA the toe was way off. So I'll just play with it a little and get the toe/camber within drivable range then head out to the alignment shop.
Old 05-17-2015, 04:58 PM   #10
wparsons
wparsons's Avatar
Set the LCA length to the same length as the stock one, and that should get your toe back close enough to drive.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
TRD Spring Install - Alignment nastynate88 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 05-07-2015 11:54 AM
Will OEM camber bolt install affect alignment B-R-Z Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 05-23-2014 11:30 PM
Alignment needed after front camber bolt install? ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 08-31-2013 12:13 AM
RCE yellow springs. Expected alignment settings after install. diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 02-24-2013 02:48 PM
Coil Install + alignment in Bay Area? BlaineWasHere Southern California 21 08-27-2012 12:10 AM
