Old 02-24-2013, 01:38 AM   #1
diss7
Drives: AE86, 2x GT86, TE27
RCE yellow springs. Expected alignment settings after install.
Am considering the RCE yellows after reading the numerous reviews on here. Just trying to determine whether I need the camber/castor correction add ons as well.
What are the expected alignment specs I will see after putting the springs in? I don't want to buy things unless I need them, but at the same time I don't want to install the springs, get the car up on the hoist and find the alignment is not ideal.
Cheers
diss7 is offline   Reply With Quote
Old 02-24-2013, 06:47 AM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Well I had Litchfield here in the UK install some similar drop springs on mine. They know their setups well and was told that it wasn't necessary for that kind of drop. If you want any form of adjustability for changing for tracks/road etc then it may be worth doing. If you want to "set and forget" then the OEM setup will do. Obviously it depends on what you want the settings at in the 1st place though!
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-24-2013, 07:04 AM   #3
sw20kosh
Drives: 2013 Black FR-S
should be no camber change in the front. So 0 camber front.
I saw -1.5 to -2.0 in rear
Old 02-24-2013, 08:07 AM   #4
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
To OP: to avoid increasing understeer with the added negative camber in the rear, consider some OEM crash bolts and possibly camber plates to help increase negative camber in front as well.
enjoyminutemaid is offline   Reply With Quote
Old 02-24-2013, 02:47 PM   #5
whataboutbob
AutoX-10/10ths every run
I did the Racecomp Engineering springs with Whiteline camber bolts on my car. I ended up with 1.6/2.0 neg in rear, and had it adjusted to 1 3/8 neg in front. You can see photos in my build thread if your are interested.
Build thread:Here
Old 02-24-2013, 02:58 PM   #6
diss7
Thanks for the info guys. What about toe?
Old 02-24-2013, 03:13 PM   #7
whataboutbob
Zero all around on mine. Plus 8 on the caster on the front with the Whiteline front LCA caster/dive bushing.
Build thread:Here
Old 02-24-2013, 03:48 PM   #8
enjoyminutemaid
For toe, I'm going to shoot for 0 in front, and slightly positive in the rear for braking stability.
Racecomp Engineering Yellow lowering springs install special! Racecomp Engineering Mid-Atlantic 12 12-17-2015 02:34 PM
How necessary is alignment after installing new springs? switchlanez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 11-22-2012 12:52 PM
Coil Install + alignment in Bay Area? BlaineWasHere Southern California 21 08-27-2012 01:10 AM
