Old 12-30-2012, 04:19 PM   #1
ayau
Drives: Some rust bucket
Alignment needed after front camber bolt install?
I'm considering purchasing the SPC 16mm camber bolts. Is an alignment required after the install? Do toe and caster change? I'm currently running on OEM tires and would prefer to do the alignment after I get some sticky rubber mounted.
camber bolts:
[ame="http://www.amazon.com/Specialty-Products-Company-81280-Adjuster/dp/B000CB3QUI/ref=sr_1_1?ie=UTF8&qid=1356902043&sr=8-1&keywords=16mm+camber+bolt"]Specialty Products Company 81280 EZ Cam XR 16mm Adjuster Bolt - Pair : Amazon.com : Automotive[/ame]
Old 12-30-2012, 04:20 PM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
Caster wont be effected. Toe and camber will be, so yes, an alignment will be required.
The Following User Says Thank You to Calum For This Useful Post:
ayau (12-30-2012)
Old 12-30-2012, 04:26 PM   #3
ayau
if i get an alignment with the oem tires, will i have to get another alignment after i get new tires mounted? the tires will be the same as the OEM size and mounted on the same rims.
Old 12-30-2012, 04:29 PM   #4
Calum
That Guy
I'm really not sure if you're trolling or serious.
No you wont need an alignment after mounting new tires, but if you've driven enough to wear out the OEM tires it may be worth it to get an alignment incase any large potholes or even just normal wear and tear caused things to drift.
Old 12-30-2012, 04:45 PM   #5
ayau
i just wasn't sure because even though the new tires will be the same size (215/45/17), they're not necessarily identical in tread width compared to the oem tires.
Old 12-30-2012, 06:04 PM   #6
Calum
That Guy
It wouldn't mater if they were a different size. The tire size wont effect the alignment.
Old 12-30-2012, 07:03 PM   #7
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
The toe change when you add the camber bolts will be pretty negligible. I added nearly 2.5 degrees of negative camber via bolts and still had a reasonable alignment (about 1/8" toe in). I want zero toe to a little bit out, so I did adjust it, but for around town? Nah, no real need.
I'm using the factory alignment bolts up top and some 14mm SPC bolts in the bottom holes.
celica73 is offline   Reply With Quote
Old 12-30-2012, 07:23 PM   #8
ayau
according to whiteline, the official camber bolt for this car is supposed to be 16mm mounted in the top slot of the strut. the camber bolt might be carrying too much load by having it mounted at the bottom.
Old 12-30-2012, 07:49 PM   #9
celica73
Then use the 16mm up top. Don't worry about me, I'll be fine.
You still won't need an alignment.
Old 12-30-2012, 07:52 PM   #10
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
This.
Also are you doing any lowering?
Our suggestion would be to get an alignment after doing the camber bolts because you will be changing the camber and having someone check it out to make sure it's correct is a good idea.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 12-30-2012, 08:07 PM   #11
ayau
Originally Posted by AZP Installs View Post
This.
-Mike Paisan
no plans to lower it at this point. i'll get an alignment once i get the front camber bolts installed.
getting additional camber in the rear will be tricky though. maybe lowering the car to get additional rear camber might not be a bad idea.
Old 12-30-2012, 08:15 PM   #12
AZP Installs
Also changing the tires does not change the alignment.
-Mike Paisan
Old 12-30-2012, 08:52 PM   #13
Calum
That Guy
Yes you will, you still need to set the camber to ensure it's even and where you want it.
AZP Installs (12-30-2012)
Old 12-31-2012, 06:47 PM   #14
celica73
No, you will set it to the maximum you can get on each side. Yall are making this a lot harder than you have to. Assuming the car hasn't been crashed already, it will be pretty square, so doing the same thing on each side will give results that are adequate.
If it makes you feel better, pay $80 for an alignment, maybe more if you actually want a custom alignment. I'll laugh when they use those camber bolts to give exactly 0 degrees on each side, rather than the most you can get.
If the car had double a-arms up front, with 4 adjusters per side, I'd be all about going to a shop for an alignment. There are too many variables to do it easily at home, but on these cars, there isn't enough to adjust to make that worth while.
Camber Bolt Help Please! ft86Fan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 114 02-27-2019 11:13 AM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
Camshaft Bolt Coming Loose After Perrin Pulley Install WhiteBRZ Engine, Exhaust, Transmission 25 09-20-2012 08:07 AM
Coil Install + alignment in Bay Area? BlaineWasHere Southern California 21 08-27-2012 12:10 AM
Alignment needed after lowering car? Lowellrenzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-16-2012 02:57 PM
