Old 05-23-2014, 11:28 AM   #1
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Will OEM camber bolt install affect alignment
Can I install these without affecting my alignment?
I installed Eibach Pro-Kit sorings recently and had my car aligned. I was wondering if I can put these bolts in to get more negative camber without messing up the toe. I'm thinking no, but thought I'd ask since I don't know if toe would be affected by this.
I know, I know, I should have put these in before my alignment.
Old 05-23-2014, 12:07 PM   #2
jprice130
AutoX Nut
Drives: 2020 Toyota Supra
Installing the OEM camber bolts can definitely affect the toe-in/toe-out of your front wheels. If you install the bolts and use them to increase negative camber, then you will also increase toe-in. If you use the bolts to increase positive camber (not sure why you would do that...lol!), then you will get more toe-out. How much toe is affected will depend on much the camber changes relative to how you're aligned now.
jprice130 is offline   Reply With Quote
Old 05-23-2014, 12:27 PM   #3
Wepeel
Drives: '13 BRZ Ltd
In my experience the camber bolt changed the toe alignment very little, if at all. IMO definitely not enough to require another alignment. YMMV. Obviously, if you put them in and it drives oddly then you'll need to get it aligned.
Wepeel is offline   Reply With Quote
Old 05-23-2014, 01:02 PM   #4
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Yes it will affect it.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 05-23-2014, 01:07 PM   #5
B-R-Z
B-R-Z's Avatar
I don't think you'd notice a slight toe issue until you see bad tire wear, which is too late. I'll hold off until next year or so when I need another alignment.
[/thread]
Old 05-23-2014, 01:21 PM   #6
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
i had the alignment checked before and after. no change.
edit: for reference, i have rs-r superdowns
supramkivtt2jz is offline   Reply With Quote
Old 05-23-2014, 01:58 PM   #7
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
The toe change with OEM camber bolts is pretty minimal. It will toe in slightly, but not enough to ruin tires. I think it was about 1/16" toe-in for each degree of camber added per side.
So, get the camber bolts, max negative camber and get 1/8" toe in.
celica73 is offline   Reply With Quote
Old 05-23-2014, 04:41 PM   #8
B-R-Z
B-R-Z's Avatar
I actually had the bolts prior to the alignment but I just didn't have them put in, but now I'd like to get the extra camber. I might go for it for the minimal toe-in I'll end up with.
Here's my alignment results
Old 05-23-2014, 05:19 PM   #9
calibrz
Turbo 86
Drives: GT86
it woult last too long with oem bolts
10 - 1 = 0
real math
calibrz is offline   Reply With Quote
Old 05-23-2014, 11:30 PM   #10
troek
troek's Avatar
Drives: 2012 Toyota 86
I have camber bolts installed in both holes, and rsr super downs. Drives strait, and no abnormal wear after a couple thousand kilometers.
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 01:10 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
Alignment needed after front camber bolt install? ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 08-31-2013 12:13 AM
Whiteline Camber bolt install TimR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 06-06-2013 08:33 AM
