Old 01-09-2015, 12:07 PM   #1
HotLavaChick
HotLavaChick's Avatar
Drives: '15 Hot Lava FRS
thumping / clunking in trunk?
just got my FRS and don't usually have the crappy stereo on much but i hear clunking or loud thumps sometimes from trunk. i have nothing it in. maybe because theres not much insulation? i don't hit anything! lol
HotLavaChick is offline   Reply With Quote
Old 01-10-2015, 01:35 AM   #2
steve99
yess common issue
http://www.ft86club.com/forums/attac...6&d=1352827746
Old 01-10-2015, 01:49 AM   #3
You nailed it with the "not much insulation" comment. The TSB Steve cited was specific to some early 13s and was fixed for later production cars so isn't likely the cause (still worth checking though).
You will get used to hearing all sorts of weird and wonderful noises from pretty much every area of the car. None of these noises are unusual really it is just most other cars are insulated enough you just don't hear them.
Unless you start getting exactly the same noise that never changes I would not worry. Just drive and enjoy.
Oh ya... I am sure you have heard about the fuel pump "crickets". If you start to get the chirping learn to love it because there is still nothing that can be done about it even though some people have suggestions they think works!
Old 01-10-2015, 06:19 AM   #4
steve99
yep plenty of weird noises in these cars.
mine is very late 2013 and i have rear deck creaking noise. :-)
E85 fixes my crickets
E10 fuel gets them going
non ethanol fuel ie 100% petrol shuts them up again
they generally get more excited when it hot
but everyones fuel blends and additives are different. same on my friends cars.
Old 01-10-2015, 11:47 AM   #5
Freetime
Freetime's Avatar
Drives: Raven Manual FRS
check to make sure the spare tire and accessories are snug?
Maybe its the LSD you hear? Mine occasionally thumps around corners
Freetime is offline   Reply With Quote
Old 01-10-2015, 01:33 PM   #6
gravitylover
The tools bounce and clang. The only time it doesn't happen is when I have large heavy things in the trunk holding them down.
Old 01-10-2015, 02:30 PM   #7
Nate.
Drives: 2014 Whiteout FR-S
I got the rear deck popping on my '14. Dealer blamed my lowering springs and wouldn't touch it since they weren't installed by them. Low and behold, I pulled the rear deck cover and did the procedure outlined in the TSB and voila. no more popping.
Nate. is offline   Reply With Quote
The Following User Says Thank You to Nate. For This Useful Post:
Tcoat (01-10-2015)
Old 01-10-2015, 02:36 PM   #8
Thanks! I think you are pretty much the first later model guy I have heard to have that issue but glad it worked. I will watch (well listen) for it but right now with the cold I have so many rattles, squeaks, thumps, bangs and other bizarre noises I wouldn't know if that was one of them or not!!!!
Old 10-07-2015, 08:21 AM   #9
g0odspeed
Drives: 2013 Scion FR-S Asphault
What is this TSB you speak of?
g0odspeed is offline   Reply With Quote
Old 10-07-2015, 08:33 AM   #10
http://www.ft86club.com/forums/attac...1&d=1352827748
Old 10-07-2015, 09:08 PM   #11
roddy
roddy's Avatar
Drives: '13 Ultramarine
Are you sure you don't have a Trunk Monkey?
[ame="https://www.youtube.com/watch?v=l8oPVVGYQ40"]Trunk Monkey Commercials - YouTube[/ame]
The Following User Says Thank You to roddy For This Useful Post:
Tcoat (10-13-2015)
Old 10-13-2015, 09:02 AM   #12
g0odspeed
I keep looking for it but I can never seem to stop quick enough to pop the trunk and catch him.... =(
The Following User Says Thank You to g0odspeed For This Useful Post:
Tcoat (10-13-2015)
The clutch is clunking Ashley Scion FR-S / Toyota 86 GT86 General Forum 22 11-14-2021 10:30 PM
Clunking in rear suspension toeout Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 01-21-2015 04:11 PM
clunking when turning when stopped nickmerronesucks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-24-2014 09:36 AM
Clunking gears when shifting? hmkk Issues | Warranty | Recalls / TSB 4 02-19-2014 06:14 PM
Transmission Clunking (A/T) Mr. J Issues | Warranty | Recalls / TSB 6 01-01-2013 07:11 PM
