Old 08-22-2012, 05:27 PM   #1
Ashley
Drives: White Scion FR-S
The clutch is clunking
My clutch is making this clunking noise when i switch it into first gear...is anyone having these same issue w theirs?? Its only 2 days old
Ashley is offline   Reply With Quote
Old 08-22-2012, 05:30 PM   #2
vobla6.0
Resident Douchebag
Drives: balla'
Please check this thread out:
http://www.ft86club.com/forums/showthread.php?t=11266
vobla6.0 is offline   Reply With Quote
Old 08-22-2012, 05:33 PM   #3
FRiSson
Drives: FR-S MT
Is it a clunking, or more like a crunchiness, like worn synchros?
FRiSson is offline   Reply With Quote
Old 08-22-2012, 05:44 PM   #4
Ashley
Its a clunk it shakes the car when i shift into first Say if im sitting at the lights about to go
Old 08-22-2012, 06:19 PM   #5
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Try keep the clutch in, wait for 3 secs, and then put it in 1st gear. If you don't get the noise that way, then I believe it's normal. My other MT did this also.
Sigh-on-Rice is offline   Reply With Quote
Old 08-22-2012, 07:07 PM   #6
kendalldwhite
kendalldwhite's Avatar
Drives: Mint-Tiffany blue FRS
mine does it to. my mustang has been doing it for the passed 100000 miles and nothings broke yet
kendalldwhite is offline   Reply With Quote
Old 08-22-2012, 07:08 PM   #7
pinoyplaya
Drives: WRB MT-BRZ LMTD
My clutch does that.
Also, today, when I tried to switch from 2nd to 3rd gear at around 4k RPM, I grinded for some reason. Hmmm. I've never grinded while upshifting.
BYE: WRB MT-BRZ LMTD
Drove the car off the lot at 8/6/12 @ 8:06 PM
Traded for Black 2013 Camaro 2SS RS
pinoyplaya is offline   Reply With Quote
Old 08-22-2012, 07:14 PM   #8
chipz91
chipz91's Avatar
Drives: Toyota Corolla, Asphalt (MT) FR-S
I think its normal, I just posted a Thread about my transmission making sounds a couple days ago. Apparently I think its normal. My trans. makes a clunk like sound too. Im guessing its the way they built it... and I've just had my car for 6 days so far. I found out on mine, when taking off from a dead stop at 1st gear, it will shake if you let go of the clutch and not accelerating while around 1500rpm or lower...
chipz91 is offline   Reply With Quote
Old 08-22-2012, 07:32 PM   #9
ayau
Drives: Some rust bucket
probably a combination of the transmission not fully warmed up and moving the shifter before fully pressing the clutch pedal in. if you ever feel a slight grind, pop it back to neutral, let go of the clutch pedal, and try again. don't force it in gear.
Old 08-22-2012, 07:37 PM   #10
pinoyplaya
Well, its not a loud grind. Its just a grind that you feel on the gear shifter. It didnt make any noise or anything. You can just feel some force on the shifter then it goes in gear. Its like a millisecond.
Currently my BRZ has around 750 miles. But today I went to like 6k RPM I couldnt resist! I needed some taste.
Need to drive more to break it in lol.
But I think its already broken in.
Old 08-22-2012, 07:43 PM   #11
ayau
i wouldn't worry about hitting 6k rpm once in a while. this isn't 1960s anymore. it's pretty hard to destroy modern engines.
the shifter doesn't feel as smooth when the transmission hasn't warmed up yet. shift below 3k rpm until your engine/tranny has warmed up. i get the same feeling on mine.
Old 08-23-2012, 10:57 AM   #12
Ashley
At least im not the only one hearing it seems like it only does it when im sitting at the lights in neutral then i throw it into first. I called the dealership yest becuz my car cldnt start it was locked up n he said he never heard of any issues w the car...yea right lol
Old 08-23-2012, 10:59 AM   #13
Ashley
Yup this is how i shift does seem a lot smoother plus im scared to take it over 3 rpm until it breaks in im babying it lol
Old 08-23-2012, 11:10 AM   #14
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
you can go up to 4k rpm for break in period according to the manual.
under 'emergency situations' above that
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
Clutch billysangi BRZ First-Gen (2012+) — General Topics 10 06-15-2012 02:29 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
