Old 04-16-2014, 12:29 AM   #1
tzhu07
Easiest oil change
topside pump oil change via dipstick tube + topside filter change = painless
Anything I can do to circumvent going underneath my car, I'll do it.
tzhu07 is offline   Reply With Quote
Old 04-16-2014, 01:03 AM   #2
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
how many times can you keep doing that way though? the oil drain plug washer is supposed to be replaced every oil change.
DuMa is offline   Reply With Quote
Old 04-16-2014, 01:08 AM   #3
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
Only because its a crush washer...if you do not remove the bolt the washer doesnt need replacing....
Fett4Real is offline   Reply With Quote
Old 04-16-2014, 01:14 AM   #4
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
I just installed one of these.
Fumoto oil drain valve.
Now the hardest part of oil changes is finding something to keep me occupied while I wait for it to drain.
Wise is offline   Reply With Quote
Old 04-16-2014, 02:19 AM   #5
M3_Dust
all of the contaminants and sediment wind up on the bottom of the oil pan so you are continuously putting that stuff through your engine if you just suck the fluid out the top vs. draining out of the bottom of the pan. sure it's easier but you're not doing your engine any favors
M3_Dust is offline   Reply With Quote
Old 04-16-2014, 02:20 AM   #6
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Most of that stuff should be in the oil filter anyways.
N1rve
Old 04-16-2014, 02:22 AM   #7
M3_Dust
no filter is capable of 100% removal of contaminants, if that was the case then the oil you drain would always be perfectly clean...it's transparent when you put fresh oil in and black when you drain it out
Old 04-16-2014, 02:25 AM   #8
N1rve
N1rve's Avatar
Well then the logic for the reverse is true then, since you're draining the oil, there will still be oil left in the motor in the nooks and crannies, which means there will still be contaminants in the engine....unless you actually do an engine flush (which I don't think anyone does).
N1rve
Old 04-16-2014, 02:28 AM   #9
M3_Dust
of course, you can't remove 100% of the oil either, but gravity is definitely your friend and the heavier stuff will find it's way to the bottom and you are still going to remove a significantly greater amount this way vs. the topside extractor
Old 04-16-2014, 09:58 AM   #10
torqdork
torqdork's Avatar
Drives: RV-7
And the drain plug magnet should be cleaned off during every change to remove ferrous bits.
torqdork is offline   Reply With Quote
Old 04-16-2014, 10:13 AM   #11
TM
TM's Avatar
Drives: DGM BRZ 6MT
Takes less than 10-minutes to do an oil change with the Fumoto valve. I don't even need a tube or a drain pan. I just position an old motor oil bottle underneath the valve and let it drain right into the bottle and then drop it off at an auto shop. Can't get any easier than that.
TM is offline   Reply With Quote
Old 04-16-2014, 12:48 PM   #12
Mikem53
Drives: FR-S 6MT
Topside oil changes are fast and convenient...
Thru the pan is more complete in cleaning out the sump.
Mikem53 is offline   Reply With Quote
Old 04-16-2014, 12:53 PM   #13
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Except the stock oil pan drain plug isn't magnetic.
-alex
Old 04-16-2014, 08:12 PM   #14
roddy
roddy's Avatar
Drives: '13 Ultramarine
Lucky dog got a magnetic drain plug with his car...must be a 10 series thing.
easiest color to keep looking clean? fatoni Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 25 10-10-2013 07:21 PM
Easiest way to get to the over-pipe? Doing an install... seven Engine, Exhaust, Transmission 7 02-03-2013 07:38 AM
Colors easiest to keep clean yet looks good fitcious Scion FR-S / Toyota 86 GT86 General Forum 31 01-16-2013 02:22 PM
First Oil Change Jehuty77 CANADA 14 08-09-2012 11:54 PM
When to do your first oil change, and why... MrBodyMassage Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 07-17-2012 07:43 PM
