Old 07-15-2012, 11:36 AM   #1
MrBodyMassage
Drives: 1994 Toyota MR2 Turbo, WRB BRZ Lim
When to do your first oil change, and why...
I've seen many on here recommending your first oil change at 1,000. I'm of the opinion that you should wait til 3,500-5,000 miles to do your first change. Here's why: The factory fill is 0w20 synthetic, so it's not dino oil. There may very well be small metallic shavings from break-in, but those all should be caught by the oil filter. The main reason to leave it in the recommended interval is this:
Analysis was done by Toromont Caterpillar ($CDN 20 including tax and shipping).
Iron 20
Chrome 0
Moly 974
Aluminum 5
Copper 83
Lead 0
Tin 1
Titanium 0
Nickel 0
Silver 0
Silicon 229
Sodium 9
Potassium 5
Zinc 918
Magnesium 13
Phosphorus 939
Barium 4
Soot UFM # 0
Sulfur UFM # 22
Oxidation UFM # 18
Nitrates UFM # 9
Viscosity cSt at 100C 7.15
TBN 5.0
TAN 1.10
Antifreeze negligible
Fuel Dilution negligible
Water negligible
The comment from Toromont was "Wear levels are consistent with normal break-in wear"
The above is an oil analysis done of a factory fill from a FB25 in a 2011 Subaru Forester. It was taken from http://www.bobistheoilguy.com/forums...Number=2251431.
What do these numbers mean? Basically the Moly, Zinc, and Phosphorus are higher than normal oils. This seems to be part of a stronger additives package put in to the factory fill.
From Idemitsu Lubricants of America in regards to an email about Subaru and Toyota 0W-20:
First, just so you know where the information is coming from, Idemitsu supplies most of the OEM’s for both Factory fill and service fill. In the case of Toyota, we do not supply their service fill oil so I cannot comment on that particular formulation.
OEMs specify Moly in their factory fill formulations to increase fuel economy during the initial period. In general a factory fill formula will be more robust in the additive treatments etc. This is done for a variety of reasons which I will not go into here.
Some of the service fill formulations also contained molybdenum however, with the transition to the ILSAC GF-5 specification, most 0W-20 service fill 0W-20 formulations now do not have Moly. That being said, you are always safest following the OEMs recommendations. All service fill OE formulas that we supply have been submitted to a full battery of tests at that respective OEM’s R&D facilities in Japan and have been approved.
Is this being super anal? Sure it is. That's why we're all on this website, specifically in this subforum
If you changed at 1,000 miles will you ever notice a difference? Probably not. I just posted this as food for thought.
MrBodyMassage is offline   Reply With Quote
Old 07-15-2012, 11:45 AM   #2
getbent
Drives: 2013 FR-S Blue MT
Thats not too bad of a UOA, however after only 1400 miles its already a thin 20 weight oil.
Iron and Copper are already a bit high (due to break-in obviuosly).
How thin will the oil be and how many ppm will be in there at the 7500 mile recommended first oil change?
I would just assume get that stuff out of the engine.
Edit: I am interested in seeing more UOA's from our FA20 to see whether the DI has fuel dilution issues just as nearly every other DI engine does.
getbent is offline   Reply With Quote
Old 07-15-2012, 09:02 PM   #3
jarviz
jarviz's Avatar
Drives: Raven FRS MT
I haven no idea what your post just said lol. I just got an oil change though at around 1600mph based on what other members have said regarding the metal shavings.
jarviz is offline   Reply With Quote
Old 07-15-2012, 09:40 PM   #4
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
Whoa that's fast!
Subie is offline   Reply With Quote
Old 07-15-2012, 11:14 PM   #5
YukiHachiRoku
Lex Luger
YukiHachiRoku's Avatar
Drives: 2004 GS430
Well, with scions complimentary service for first two years or 25,000 miles, every 5,000 miles is recommended by them, and it's free. So that is the route I will take. 5k, 10k, 15k, 20k etc..
I did ask the service tech about @ 1K, and he told me that's "old school'....
YukiHachiRoku is offline   Reply With Quote
Old 07-16-2012, 01:20 AM   #6
_hollywood
Drives: 97 itr sold
The first oil change is 7500k
FR-S #56 of 86 Raven MT ***FOR SALE***
_hollywood is offline   Reply With Quote
Old 07-16-2012, 05:14 PM   #7
GFo12ce
Drives: '10 Nismo 370Z
On that note I thought I link my post again to this guys oil quiestion. Also it's an area go get something new for the car you may not have thought of. not to mention maybe some extra insurance for those that plan to keep thier cars a long time. I did them to my Z:
http://www.ft86club.com/forums/showp...86&postcount=3
GFo12ce is offline   Reply With Quote
Old 07-16-2012, 05:23 PM   #8
luxmn
First FR-S
Drives: Whiteout MT FRS
changed oil at 1000 miles for break-in purpose and because it was free (you got to work your service rep )
and i can vow for it, the engine came alive afterward
luxmn is offline   Reply With Quote
Old 07-16-2012, 06:51 PM   #9
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
My god who is your mechanic .. able to expel oils and replace the oil and oil filter all at 1600 mph!
I've been debating doing it at 1k or 3k ...
Old 07-16-2012, 07:04 PM   #10
ahausheer
Re-member
Drives: Toyota camry
I think if this were beneficial low production high end sports cars like the Corvette ZR1, M3/5, GTR, etc. would recommend an early first change, but they dont. So I wont change it early. And how do we know the moly is part of an additive package as opposed to being left over from assembly lube or normal production process.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 07-16-2012, 10:25 PM   #11
FutureFT86
FutureFT86's Avatar
Drives: 13 Scion FR-S
Originally Posted by Subie View Post
Whoa that's fast!
you made me lol!
FutureFT86 is offline   Reply With Quote
Old 07-17-2012, 01:27 PM   #12
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
it's known as oil sample testing
there are a number of places that do it
they take a small sample of your oil and analyze it's contents. This provides a good analysis of your engines overall health, particularly whether you have coolant or gasoline enter your oil circulatory system.
doing an oil test every 10-15k is an effective way to keep tabs on your engines health and provide warning signs to possible problems that will take a lot longer to show up "mechanically"
Old 07-17-2012, 02:05 PM   #13
hankster
hankster's Avatar
Drives: 2013 FR-S Argento
Originally Posted by GFo12ce View Post
link no linky
hankster is offline   Reply With Quote
Old 07-17-2012, 06:59 PM   #14
GFo12ce
Originally Posted by hankster View Post
link no linky
Wierd, I used the link just to my post, heres the whole thing. Mines #3 (so you don't have to fish for it):
http://www.ft86club.com/forums/showthread.php?t=11812
DIY BRZ / FR-S Oil Change RallySport Direct DIY (Do-It-Yourself) Guides 169 09-01-2018 02:42 AM
Oil change after break in? oops86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 32 08-03-2012 12:09 AM
oil change question jarviz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 07-19-2012 06:14 PM
Oil Change Questions #87 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 31 06-28-2012 11:06 PM
Do you change your own oil? If so, why? SteelReign Other Vehicles & General Automotive Discussions 76 04-15-2012 04:44 AM
