CANADA Canada
Old 07-16-2012, 03:09 PM   #1
Jehuty77
Drives: AE86
First Oil Change
Have You done yours yet, what would you do yours at?
I just finished the break in procedure(1600km) and I'm wondering if its time to change it up now.
Jehuty77 is offline   Reply With Quote
Old 07-16-2012, 03:52 PM   #2
zex
zex's Avatar
Drives: Subaru WRB BRZ Limited
I would do mine at 3000km
zex is offline   Reply With Quote
Old 07-16-2012, 04:39 PM   #3
GFo12ce
Drives: '10 Nismo 370Z
When I was breaking in my Z I threw on an oil filter magnet and a magnetic oil drain plug. Some might argue that it may not do much but they were cheap and If it works to trap shavings I figure why the hell not. I still use them both.
http://www.shopfiltermag.com/tech.php#technology
I believe I got the magnet through Summit Racing. Serveral people make the drain bolts. I'd probably go with a brand you've heard of. Mines Peak Performance (I know the shop that make them personally so I got that). I recently saw an ad for Mishimoto who now makes them, Greddy, Kicks, ircuit Sports, NRG ECT. I don't use the Nissan paper element filters either (not sure what Subaru uses), I use the K&N ones. Lastly for the oil I like, Walmart has most of the local auto parts store beat on price so check there too.
GL
GFo12ce is offline   Reply With Quote
Old 07-16-2012, 05:05 PM   #4
AJ PwR
AJ PwR's Avatar
Drives: R35 R56 CZ4A ZC6
Send a message via ICQ to AJ PwR Send a message via AIM to AJ PwR Send a message via MSN to AJ PwR
I will probably do mine at around 2000km. I think there will be quite a bit of debris after the break in.
I love the idea of the filter magnet but you can't really see how much metal shavings that the motoring was making.
A magnetic drain bolts makes more sense.
This is the one that I got for my car !
AJ PwR is offline   Reply With Quote
Old 07-16-2012, 05:25 PM   #5
narfy
short asian guy
narfy's Avatar
Drives: ZN6, VZN185
ben, how much is the magnetic drain plug?
VZN185 - 32" BFG AT, OME suspension, ARB bumper, lightforce lights, TRD trans cooler, TRD exhaust, budbuilt plates...
ZN6 - stock with HIDs and LEDs...
fng@regencyauto.com
narfy is offline   Reply With Quote
Old 07-16-2012, 07:46 PM   #6
jesseps
Drives: Scion FR-S
I'll call the dealership tomorrow and ask them if they can do mine... I am nearing 2500 km.
jesseps is offline   Reply With Quote
Old 07-17-2012, 12:04 AM   #7
Aznek
Drives: 2013 White Scion FRS
Would the metal shavings be stuck in the oil tank if I used one of these drain valves?
http://www.qwikvalve.com/fumoto-f108s-valve.html
Aznek is offline   Reply With Quote
Old 07-17-2012, 02:03 PM   #8
GFo12ce
I use both. I understand what you are saying but wouldn't you rather have the filter magnet (which has several more strong neodium magnets than the bolt) there to get any extra shavings the bolt doesn't? Whether you get to see them or not is just kind of making you feel good about your purchase lol. Obviously either one is a good idea if you can't afford both though.
Old 07-17-2012, 03:03 PM   #9
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
it can if you take a hacksaw to it.
Old 08-09-2012, 01:17 PM   #10
Jehuty77
Drives: AE86
So I went in to Toyotato get the oil changed at 3000km, the guy there told me come back at 5000 because we "should not change the oil too early" and that "Changing it after 2000km is old school thinking and not the case anymore"
thoughts?
Old 08-09-2012, 01:20 PM   #11
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
i changed mine at 2500 at mr.lube, brought in my own oil and filter, told them to put the name of the oil in the memo field.
if you're not gonna hit the track, i say do it according to the manufacturer
if you're gonna rip on the engine, ignore everything the techs say.
Old 08-09-2012, 10:17 PM   #12
roddy
roddy's Avatar
Drives: '13 Ultramarine
Is it needed that early? Probably not, but I can't leave anything alone. I don't recall the exact mileage, but I changed my oil at about 2000 KMs, and followed up by changing the transmission (manual) and rear end lube at around 3000.
Old 08-09-2012, 10:27 PM   #13
ArKiTeCkT
ArKiTeCkT's Avatar
Drives: 2010 Gen Coupe, 2013 BRZ 6MT S.Tech
^I have a manual transmission too. Is it recommended to change transmission fluid?
ArKiTeCkT is offline   Reply With Quote
Old 08-09-2012, 11:43 PM   #14
Jehuty77
Drives: AE86
I dont think changing the tranny fluids and rear end fluids is required so soon but i could be wrong
DIY BRZ / FR-S Oil Change RallySport Direct DIY (Do-It-Yourself) Guides 169 09-01-2018 02:42 AM
When to do your first oil change, and why... MrBodyMassage Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 07-17-2012 07:43 PM
Oil Change Frequency bneale Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 06-08-2012 10:25 AM
Color Change Dark_Angle Mid-Atlantic 10 05-30-2012 02:00 PM
Do you change your own oil? If so, why? SteelReign Other Vehicles & General Automotive Discussions 76 04-15-2012 04:44 AM
