Old 02-02-2013, 09:22 PM   #1
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
Wink Easiest way to get to the over-pipe? Doing an install...
So I have my cat-back all off, I pulled off the metal shielding under the engine bay, I need to jack up my car a little higher but it's on jack stands.
Just wondering if someone did the over-pipe install already and if you need to drop the header or what was the easiest way to get to it?
Thanks
-Seven || youtube.com/turnsevenvideo
2012 C6 Grand Sport 4LT
2015 Mazda 3i-T/Tech
seven is offline   Reply With Quote
Old 02-02-2013, 09:33 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
If I recall correctly, people that replaced the overpipe by itself, (meaning it not Nameless setup that combined the overpipe and frontpipe into one piece) you can remove the shielding and wiggle it out without needing to lift the engine and not needing to touch the header.
Old 02-02-2013, 09:34 PM   #3
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
You need to loosen off/remove the secondary catted pipe. Much easier than taking the header, as there is no wiring harnesses/o2 sensors attached to it.
AVOturboworld is offline   Reply With Quote
Old 02-02-2013, 09:34 PM   #4
dabocx
dabocx's Avatar
Drives: Scion FRS
I lifted the motor slightly.
dabocx is offline   Reply With Quote
Old 02-02-2013, 09:57 PM   #5
seven
Tells it like it is
seven's Avatar
Well I got the Agency Power one, so it's slip fit.
Got ya. I definitely need to jack this thing up higher. And airtools ftw
Old 02-02-2013, 10:49 PM   #6
TyperRspec789
Version 2 Coming Soon...
TyperRspec789's Avatar
Drives: Turbo Argento FRS, Asphalt FRS
Thanks
I installed my overpipe by going through the front then twisting and turning until it got through.. I did NOT need to lift the engine or remove the header.
TyperRspec789 is offline   Reply With Quote
Old 02-02-2013, 11:07 PM   #7
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
I lifted the engine to do the nameless combo pipe. Just loosened the bolt on the passenger side of the subframe and jacked up the engine. Was pretty simple and made the pipe a breeze to install.
Flat Black VW is offline   Reply With Quote
Old 02-03-2013, 07:38 AM   #8
Mobius357
Drives: '15 WRX '13 Legacy '07 Colorado
I jacked up the engine an inch or two, it's easy to do and made short work of swapping overpipes.
Mobius357 is offline   Reply With Quote
FA20CLUB Over Pipe Front Pipe & Cold Air Intake Now Ready FA20Club.com Engine, Exhaust, Transmission 171 02-27-2013 09:44 AM
Will a resonated front pipe make alot less noise than test pipe? Mike86 Engine, Exhaust, Transmission 8 01-26-2013 07:24 PM
Colors easiest to keep clean yet looks good fitcious Scion FR-S / Toyota 86 GT86 General Forum 31 01-16-2013 02:22 PM
MXP EXHAUST and FRONT PIPE FRS BRZ in stock ready to install or ship AMPLIFIED MOTORSPORT Engine, Exhaust, Bolt-Ons 0 11-08-2012 09:09 PM
