Old 02-07-2014, 12:42 PM   #1
qqzj
Drives: MDX, Camry
Washer for oil drain plug missing? Kind of urgent.
Just did the break-in oil change. Actually I am in the middle of it. Everything went okay. But I could not find the used washer in the drain pan or on the plug. I am really confused whether I should put on my new washer or not.
Any quick suggestions or share your experience? I remember there was an old thread on this, but I cannot find it. Any help? Thanks.
qqzj is offline   Reply With Quote
Old 02-07-2014, 12:48 PM   #2
qqzj
Drives: MDX, Camry
Sorry, I tried to delete this thread. But I do not know how. Anyway, I finally managed to peel the OEM washer from the oil drain plug. It was hard. But it finally came off. Now I am in peace. Thanks a lot.
Old 02-07-2014, 12:50 PM   #3
TM
TM's Avatar
Drives: DGM BRZ 6MT
I haven't done an oil change yet, but doesn't your new oil filter come with a drain plug gasket?
TM is offline   Reply With Quote
Old 02-07-2014, 12:55 PM   #4
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
They aren't packaged together but if you ask for a oil filter they usually add the crush washer.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 02-07-2014, 12:56 PM   #5
frslee
Just drive it
Drives: 13' FR-S
Oil filter doesn't come with drain gasket, you mean oil drain bolt comes with gasket?
Yes it does, but you'll have to remove it from the bolt if it's first time oil change. I think the factory sprays the pan after everything is assembled, so the gasket is attached to drain plug for the first time.
gasket = crush washer
frslee is offline   Reply With Quote
Old 02-07-2014, 12:57 PM   #6
Apoc
Apoc's Avatar
lol it's usually painted on from the factory and requires some angry force to get it off.
“The World is Flat”
[||•]=(86)=[•||]
Old 02-07-2014, 01:03 PM   #7
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
http://www.ft86club.com/forums/showp...13&postcount=1
Old 02-07-2014, 01:18 PM   #8
TM
TM's Avatar
Drives: DGM BRZ 6MT
Originally Posted by Apoc View Post
They aren't packaged together but if you ask a oil filter they usually add the crush washer.
I was basing my information on this site and a couple of others.
http://subaruonlineparts.com/advance..._description=1
Does it usually not come with the gasket (i.e. if I went to the dealer to get an oil filter)?
Is this washer different from the gasket that comes with the filter?
Old 02-07-2014, 01:27 PM   #9
mav1178
mav1178's Avatar
Washer in question. The site you referenced above packages a crush washer w/ the oil filter (there's two part numbers listed for the oil filter if you look at the listing).
-alex
Old 02-07-2014, 01:43 PM   #10
qqzj
Drives: MDX, Camry
It is not. Actually the washer is quite expensive for what it really is, $1.20.
Beware || oil drain plug washer (when changing your oil) mav1178 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 11-14-2021 06:07 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 07:36 PM
Magnetic oil drain plug, effective? BRZPDX Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 02-16-2013 11:59 PM
URGENT: Missing Subaru Outback Idaho Plates involved in Homicide - Hercules, CA Flipside909 Southern California 11 10-11-2012 02:36 AM
Engine oil drain plug washer BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 06-28-2012 11:28 AM
