Drives: '89 911, '06 GTI, '13 BRZ
Engine oil drain plug washer
I just bought two oil filters for my BRZ. These are the OEM filters, same P/N as installed at factory.
Anyway, got home and opened one of the boxes to look at the filter. Filter is correct but is a drain plug seal washer supposed to be included as mine did not come with any drain plug washer. I though the washers came with the factory OEM filters. Now I've got to get back to dealer (70 miles away) or can someone point me towards an online Subaru parts outlet that I could order these washers from? Thanks!
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe 2006 VW GTI/DSG 2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten 2014 Nissan Murano SV Last edited by BMWDavid; 06-28-2012 at 09:07 AM. |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
They don't come with the filters. The parts guy should have offered them.
You can hit up an auto parts store. They're 16mm crush washers. OR... You could get a Fumoto valve and never deal with washers again. (Among other oil change headaches) |
#TrackAddicts
Drives: The Dipped Car
yeah it's a crush washer. should run under a $1 at O'Reilly's or NAPA. i too have a Fumoto...
Thanks...I'll check at my local NAPA.
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe 2006 VW GTI/DSG 2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten 2014 Nissan Murano SV |
| Subaru or Toyota drain plug? | yayforaddison | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 05-06-2020 10:59 PM |
| Spark plug removal? Changed your feelings for BRZ? | BMWDavid | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 89 | 02-07-2015 09:46 AM |
| front washer? | Filipino Royale | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-21-2012 02:06 PM |
| Spark plug type and heat | ft86-UAE | Engine, Exhaust, Transmission | 4 | 06-10-2012 10:21 AM |
| Honda to show off EV plug in concepts at Tokyo Auto Show | Dark | Other Vehicles & General Automotive Discussions | 4 | 11-10-2011 08:34 PM |
