Old 12-23-2013, 03:08 AM   #1
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Beware || oil drain plug washer (when changing your oil)
Not sure if anyone else has had this issue, but it's worth a mention.
I changed my oil drain plug to a Fumoto at the first oil change, so I didn't give this much thought. I just made sure the oil pan was clean and put on the Fumoto and called it a day...
When I cleaned the garage earlier today, I noticed my drain plug. It had the factory washer on there, glued on with the black paint used to paint the oil pan:
My best guess is that the oil drain bolt was assembled prior to the pan being assembled, and the oil pan was painted at the same time.
Be careful when you change your oil for the first time (or the most recent time). I didn't think to look for the washer as it usually falls into the pan I'm draining into, but now I know where it is.
If one were to accidentally stack washers in this case, it could cause your oil to leak from the pan.
-alex
The Following 3 Users Say Thank You to mav1178 For This Useful Post:
normancw (12-23-2013), Suberman (12-23-2013), Superhatch (12-23-2013)
Old 12-23-2013, 03:17 AM   #2
R.S-HawK
Drives: '13 Gen Coupe 3.8 R
Yeah....
Sent from my Nexus 7 using Tapatalk
R.S-HawK is offline   Reply With Quote
Old 12-23-2013, 11:06 AM   #3
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
So we're assuming that you did not put on a new crush washer?
Note: I have no idea if the Fumoto needs it or not... I'm just a chump that randomly re-uses / buys new crush washers with a good old fashioned bolt.
Chimpo is offline   Reply With Quote
Old 12-23-2013, 11:27 AM   #4
robot
There are now 2 carseats!
Drives: 2013 DGM BRZ
Fumoto uses a fiber washer and does not use a factory crush washer.
robot is offline   Reply With Quote
The Following User Says Thank You to robot For This Useful Post:
ZionsWrath (12-23-2013)
Old 12-23-2013, 12:20 PM   #5
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
o...k...usually all cars came like that when new..so, i am used to it. lol
Old 12-23-2013, 12:33 PM   #6
ZionsWrath
Thanks
ZionsWrath's Avatar
Yea I actually don't know where I put my stock plug, oops
Old 12-23-2013, 12:52 PM   #7
mav1178
mav1178's Avatar
My point is, this is something that can be easily overlooked if you are changing oil on your own, or if the dealer mechanic is not careful and/or an apprentice.
Just documenting this to help others.
And yes, the Fumoto comes with its own washer.
-alex
Sidenote: this was not an issue on my 2005 Camry, nor on the 2002 ES300. All my other ~15+ cars were all purchased used.
Old 12-23-2013, 01:03 PM   #8
OrbitalEllipses
Drives: Attitude
You've never purchased a new Subaru then.
Ranatsu (12-23-2013)
Old 12-23-2013, 08:28 PM   #9
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
I also used a Fumoto but thanks OP for the info.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 12-24-2013, 12:42 AM   #10
MagicBobert
MagicBobert's Avatar
Drives: 2014 WRB BRZ Limited
Thanks for the tip. Did my first oil change today and I might have overlooked the stuck crush washer if I hadn't seen this thread.
MagicBobert is offline   Reply With Quote
The Following User Says Thank You to MagicBobert For This Useful Post:
mav1178 (12-24-2013)
Old 12-28-2013, 02:15 PM   #11
TIsbell34
The dealership where I bought my car (wasn't a toyota / subaru place) re-used the crush washer when they changed the oil and a week or two after driving it home I noticed that there was a small leak from the drain plug and had to drain the oil again and replace the crush washer to fix it
TIsbell34 is offline   Reply With Quote
Old 11-01-2021, 07:53 PM   #12
CockpitCruiser
Custom Title
CockpitCruiser's Avatar
Drives: GT86
I broke the oem oil bolt on the 3rd oil change so hello Fumoto. 18+ oil changes later and it's still not leaking. No more dropping the bolt into the oil either
CockpitCruiser is offline   Reply With Quote
The Following 3 Users Say Thank You to CockpitCruiser For This Useful Post:
jflogerzi (11-02-2021), soundman98 (11-01-2021), Yoshoobaroo (11-02-2021)
Old 11-01-2021, 08:24 PM   #13
7 skulls
Drives: 2014 scion frs
Saw this issue with my first non dealer oil change. Fiber washers like to stick to the pan. Metal crush washers usually come off with the bolt. I always us something plastic to knock the fiber ones off the pan. Don't want any metal scrapping on that surface.
Had an 87 chevette once. Just replaced a blown motor and had filled her with new oil. Got underneath, figured I'd snug the drain bolt a little more. SNAP. Broke the bolt clean out of the pan. Torque wrenches are my friends, at work and at home.
7 skulls is offline   Reply With Quote
Old 11-02-2021, 12:14 AM   #14
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Ok, please explain how on earth you break an oil plug?
humfrz (11-03-2021), Opie (11-03-2021)
Subaru or Toyota drain plug? yayforaddison Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 05-06-2020 11:59 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 08:36 PM
Magnetic oil drain plug, effective? BRZPDX Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 02-17-2013 12:59 AM
Greedy Magnetic Drain Plug USMC -FRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 02-10-2013 07:04 PM
Engine oil drain plug washer BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 06-28-2012 12:28 PM
