Old 11-12-2013, 04:15 PM   #1
wodnr1215
Question Engine Oil Question
HI !!
I need to change the engine oil soon(3k miles). This will be my first engine oil change.
Also brz is using 0w-20 (recommended)
but I want to put 5w-30 or 10w-30
is this okay?
I heard that Mobil 1 is bad for subaru's car? If yes, why?
Which engine oil are you guys using? and oil filter ?
If I bring my own engine oil to dealer. Are they going to do it?
Thank You
wodnr1215 is offline   Reply With Quote
Old 11-12-2013, 04:32 PM   #2
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
You should check out the Mechanical Maintenance section as this has been covered many times. You'll get a lot of different answers concerning what oil and filter to use, though. There isn't a definitive answer. You should definitely read some of the info in the Mechanical Maintenance section as there's a lot of good information about oil in general there.
Mobil 1 isn't bad for Subaru engines. The reason why people have said that about Mobil 1 is because there has been a lot of people that have burned a lot of Mobil 1 when used with the EJ engines compared to other oils. However, there have also been a lot of people that have used Mobil 1 without any issues.
G_Ride is offline   Reply With Quote
Old 11-12-2013, 04:41 PM   #3
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Mobile 1 has had a bad rep in the past, specifically their non-synthetic oil that used to be what Subaru used as their oil. However, that has changed with Subaru's change to synthetic. The standard synthetic Subaru 5W-30 is actually good stuff. Not sure if you should use that or the 0W-20. 0W-20 seems a bit thin, to be honest, but I'm coming from 4.5 years of driving turbo'd imprezas with 5W-30 synthetic, so maybe the NA 2.0 likes 0W-20 better.
^GT5 Replay Photo Mode^
Old 11-12-2013, 04:52 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Honestly?
If you have to ask, just have the dealer do the oil change for you, including oil. The more you mess with something you don't know or understand, the more you'll screw it up.
-alex
Old 11-12-2013, 04:58 PM   #5
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
Why do you want to go to a thicker oil?
chrisl is offline   Reply With Quote
Old 11-12-2013, 05:27 PM   #6
BRZnut
Drives: BRZ DGM Limited
just did mine......used Mobil-1 0W-20 and the black Subaru filter.
Old 11-12-2013, 06:03 PM   #7
SirBrass
SirBrass's Avatar
Originally Posted by mav1178 View Post
Honestly?
-alex
For some, you GET oil changes included with the car for the first 24k miles or 2 years, whichever comes first (essentially with them estimating an oil change about every 6k miles, so you get a max of 4).
If you're getting your first 4 changes included, USE them, unless you have reason to suspect your dealership's service department is about as inept as Jiffy Lube.
Old 11-12-2013, 06:16 PM   #8
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
Eneos sustina is good
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 11-12-2013, 06:29 PM   #9
Porsche
Drives: 2013 BRZ Ltd. MT
Originally Posted by wodnr1215 View Post
HI !!
is this okay?
http://www.ft86club.com/forums/showp...7&postcount=20
Porsche is offline   Reply With Quote
Old 11-12-2013, 10:04 PM   #10
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
If this is your first time doing an oil change, this is the perfect car to learn how to do it. Simply use the scissor jack you have in the rear trunk, jack the side of the car up to give you enough clearance and then use a Jack Stand to support the car. Go underneath the car and unbolt the oil drain plug and simply change the oil filter and add 5.5 quarts of oil and check the fluid level to be sure it's in the correct spot and youre done.
If you are confused because you are like me and need real-life picture/video reference then there are plenty of Youtube videos on what fluid level you should be looking at and where an oil drain plug might look like. Goodluck
LeeMaster is offline   Reply With Quote
Old 11-12-2013, 10:12 PM   #11
frslee
Just drive it
Drives: 13' FR-S
You bought an enthusiast's car and doesn't even know the basic oil differences...?
frslee is offline   Reply With Quote
Old 11-12-2013, 10:13 PM   #12
Muskokan
Drives: white Sport-tech
I used Mobil 1 0w 20, haven't burnt any.
Even helped gas mileage a bit in my opinion.
Muskokan is offline   Reply With Quote
Old 11-12-2013, 10:42 PM   #13
wodnr1215
hahah sorry lol
FINALLY engine is broken in...engine/tranny smell? denverizzles Engine, Exhaust, Transmission 18 09-15-2013 08:12 PM
Engine Noise Question TONYpepperon1 Issues | Warranty | Recalls / TSB 13 09-01-2013 05:22 AM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
Engine swap question koyv90 Engine, Exhaust, Transmission 4 03-22-2012 01:08 PM
Engine Question alex05 Engine, Exhaust, Transmission 4 02-21-2012 06:08 AM
