Old 03-22-2012, 05:20 AM   #1
koyv90
Rocket Bunny FRS
Drives: 2013 Rocket Bunny FRS
Engine swap question
Say you swaped in a ej engine to get a quick and reliable turbo build.
Would you still get the same lower center of gravity as the new engine?
Would the ej engine way less than the new one?
Just two questions i wanted to ask when contemplating what you could do to the car
koyv90 is offline
Old 03-22-2012, 08:12 AM   #2
powertrip
Drives: Mercedes C320, S2000
no and no.
unless you did some serious engineering of the swap your going to shift the balance of the weight with the turbo peripherals. IC/Turbo/Pipes/etc will weigh an extra ~100lbs upfront on the car. And the engine weighs more for the same reasons. Turbo's arent lighter than N/A.
powertrip is offline
Old 03-22-2012, 08:22 AM   #3
brufleth
Drives: 2007 WRX
In addition I don't think you could situate the EJ engine as low because of the physical dimensions of it. It would drag on the road (or nearly so). So you wouldn't have the low center of gravity either.
brufleth is offline
Old 03-22-2012, 12:59 PM   #4
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
the 1.6 DIT would shave a bit a of lbs off a 2.0L T you would have more TQ and more hp
the hood has ample room under it for that intercooler, just get an aftermarket hood scoop for it and you're good to go
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline
Old 03-22-2012, 01:08 PM   #5
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
Would the ej engine weigh less than the new one?
1. Search
2. No, you would likely to place the EJ further up and forward to accept the pluming. Changing the COG.
3. No, EJturbo would likely to be heavier because of the more items present on the long block.
4. Its confirmed that the EJ engine does not blot up to the AZ6 transmission, so additional work may be required to get it to fit..or use the WRX transmission which will change placement of many things.
/thread
WingsofWar is offline
Engine Swap ... Macavely Engine Swaps 220 07-25-2012 03:58 AM
[Noob Question]Will you be able to swap BRZ and 86 headlights? Slide Cosmetic Modification (Interior/Exterior/Lighting) 41 02-18-2012 01:26 AM
Headlight Swap Question nogaroblues4 Scion FR-S / Toyota 86 GT86 General Forum 9 02-07-2012 02:45 AM
4U-GSE: the new engine swap for old Toyotas no_name Engine Swaps 17 12-19-2011 09:50 PM
engine swap thread aspera Engine Swaps 231 03-15-2011 05:10 PM
