| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
HI !!
![]() I need to change the engine oil soon(3k miles). This will be my first engine oil change. Also brz is using 0w-20 (recommended) but I want to put 5w-30 or 10w-30 is this okay? I heard that Mobil 1 is bad for subaru's car? If yes, why? Which engine oil are you guys using? and oil filter ? If I bring my own engine oil to dealer. Are they going to do it? Thank You |
#2 |
Drives: Some kind of Subaru
You should check out the Mechanical Maintenance section as this has been covered many times. You'll get a lot of different answers concerning what oil and filter to use, though. There isn't a definitive answer. You should definitely read some of the info in the Mechanical Maintenance section as there's a lot of good information about oil in general there.
Mobil 1 isn't bad for Subaru engines. The reason why people have said that about Mobil 1 is because there has been a lot of people that have burned a lot of Mobil 1 when used with the EJ engines compared to other oils. However, there have also been a lot of people that have used Mobil 1 without any issues. |
#3 |
Trust me, I'm the Doctor
Mobile 1 has had a bad rep in the past, specifically their non-synthetic oil that used to be what Subaru used as their oil. However, that has changed with Subaru's change to synthetic. The standard synthetic Subaru 5W-30 is actually good stuff. Not sure if you should use that or the 0W-20. 0W-20 seems a bit thin, to be honest, but I'm coming from 4.5 years of driving turbo'd imprezas with 5W-30 synthetic, so maybe the NA 2.0 likes 0W-20 better.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#4 |
Drives: 2005 Toyota Camry
Honestly?
If you have to ask, just have the dealer do the oil change for you, including oil. The more you mess with something you don't know or understand, the more you'll screw it up. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | BRZfan (11-12-2013) |
#5 |
Drives: 2006 Cayman S, 2007 Outback 2.5i
Why do you want to go to a thicker oil?
#6 |
Drives: BRZ DGM Limited
just did mine......used Mobil-1 0W-20 and the black Subaru filter.
#7 | |
If you're getting your first 4 changes included, USE them, unless you have reason to suspect your dealership's service department is about as inept as Jiffy Lube.
#8 |
Boosted Member
Drives: 2013 SWP BRZ Limited
Eneos sustina is good
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12 |
#9 | |
Drives: 2013 BRZ Ltd. MT
http://www.ft86club.com/forums/showp...7&postcount=20 |
#10 |
Red wine
Drives: Subaru BRZ(R.I.P)
If this is your first time doing an oil change, this is the perfect car to learn how to do it. Simply use the scissor jack you have in the rear trunk, jack the side of the car up to give you enough clearance and then use a Jack Stand to support the car. Go underneath the car and unbolt the oil drain plug and simply change the oil filter and add 5.5 quarts of oil and check the fluid level to be sure it's in the correct spot and youre done.
If you are confused because you are like me and need real-life picture/video reference then there are plenty of Youtube videos on what fluid level you should be looking at and where an oil drain plug might look like. Goodluck
#11 |
Just drive it
Drives: 13' FR-S
You bought an enthusiast's car and doesn't even know the basic oil differences...?
#12 |
Drives: white Sport-tech
I used Mobil 1 0w 20, haven't burnt any.
Even helped gas mileage a bit in my opinion. |
#13 |
| FINALLY engine is broken in...engine/tranny smell? | denverizzles | Engine, Exhaust, Transmission | 18 | 09-15-2013 08:12 PM |
| Engine Noise Question | TONYpepperon1 | Issues | Warranty | Recalls / TSB | 13 | 09-01-2013 05:22 AM |
| Engine sputtering while idling with check engine light flashing, WTF | speedy racer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-27-2012 06:50 AM |
| Engine swap question | koyv90 | Engine, Exhaust, Transmission | 4 | 03-22-2012 01:08 PM |
| Engine Question | alex05 | Engine, Exhaust, Transmission | 4 | 02-21-2012 06:08 AM |
