Old 09-20-2012, 01:56 PM   #1
denverizzles
FINALLY engine is broken in...engine/tranny smell?
Finally!! I have reached 1000 miles on my car. I haven't gotten my first oil change, but i'll probably do it shortly.
Being that i hit 1000 miles i really wanted to hit redline and push that bad boy for the first time. I have to say the power is night and day from 2-4k and 5k-redline. What concerned me is that after i pulled over, i noticed a smell coming from either the engine or the tranny...couldn't tell where. do you think this smell is normal, being that it's the first time i've ever pushed the engine passed 4kish?
denverizzles is offline   Reply With Quote
Old 09-20-2012, 02:05 PM   #2
Zaggeron
Zaggeron's Avatar
Drives: '13 BRZ Limited '10 370ZR
Hard to say without knowing what the smell smelled like. In general, engines smell of enginey things when pushed hard. Nothing to worry about probably unless the smell is from something leaking and burning off on the block. Check the fluids and look for leaks and if you're OK, I wouldn't worry about it.
2013 GBS Subaru BRZ Limited 6MT
2010 PG 370z Roadster: Sport/Touring 6MT
Zaggeron is offline   Reply With Quote
Old 09-20-2012, 02:06 PM   #3
flippy
flippy's Avatar
Drives: 2013 Firestorm Scion FRS
mine always gets that smell after 4k rpms
Originally Posted by bdanisi View Post
Can we close this thread it wasn't intended to become vaginal pun fodder
flippy is offline   Reply With Quote
Old 09-20-2012, 02:06 PM   #4
wlfpck
Drives: 2015 GTI
Depends on what the smell actually is. I know it's not helpful but that's the best diagnosis that can be given.
It shouldn't be a problem. If you've broken it in property then it should be fine.
It could be the clutch if you were beating on it, launching, agressive shifting, etc.
To be honest, I don't think it should be an issue unless the smell is happening all the time. Then it is reason to be concerned.
2013 GTI - Gone
2015 GTI
wlfpck is offline   Reply With Quote
Old 09-21-2012, 05:11 PM   #5
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
^Agreed. Probably nothing to worry about if it is not constant. If you start seeing smoke, then start worrying.
Use your best judgement and take it to a shop if it becomes a concern.
-Zach
RallySport Direct is offline   Reply With Quote
Old 09-21-2012, 05:46 PM   #6
deedz
Drives: Rocket Bunny FR-S
I get the same smell too if i push the car, happed when i pushed it right after 1k
And i thought the same thing, dosnt seem to be a big deal
deedz is offline   Reply With Quote
Old 09-21-2012, 10:02 PM   #7
ModBargains
ModBargains's Avatar
Drives: FRS, M3
I think it's pretty normal on a newer car - the smell will go away over time.
-Frank
ModBargains is offline   Reply With Quote
Old 09-22-2012, 10:03 PM   #8
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
Its just the perservation wax being burned off, takes quite a lot of use before it goes away for good
Toyota 86 test driver
Tradewind is offline   Reply With Quote
Old 09-22-2012, 10:19 PM   #9
Supermassive
Supermassive's Avatar
How in the hell did you go 1000 miles and never break 4k rpm...I would be the most angry person on the road if I did that...That being said I redlined the car coming out of the parking lot the day i bought it...sideways...
To each their own I guess, 2700 miles and going in for the oil change this tuesday. No issues yet nd no wierd smells...well except for the A/C that smells weird when i first start the car.
Supermassive is offline   Reply With Quote
Old 09-23-2012, 07:33 AM   #10
jesperswe
Drives: GT86
First day I got my car I redlined it lots of time? I didn't buy a prius damn it!
My car smelt of hot rubber and hot plastic all day long.
I stunned you actually were able to never go over 4k rpm in 1000miles?!
jesperswe is offline   Reply With Quote
Old 09-23-2012, 10:50 AM   #11
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
Not taking this motor over 4k for the first 1000 miles makes no sense. Don't beat on it but the motor needs to be ran through it's RPM range and varying degrees of load. If you don't do this Engines can have a bad Ring seal. IE excessive blow by.
Gregg
jdzumwalt is offline   Reply With Quote
Old 09-23-2012, 10:52 AM   #12
EvoXDD
Trident Motorsports Owner
Drives: DGM. DD for my EvoX
the smell is 100% normal, and don't change the oil till around 3-5k because the oil that is in the engine from the factory is a special oil made for break-ins. after that go amsoil full synthetic ALL THE WAY!
previous cars:1998 chevy s10 2001 Prelude SH 1992 (JDM)RX7 FD Current Cars:2010 Mitsubushi Evo X GSR 2013 Subaru BRZ Sponsors:Mishimoto/Flossy/Tomei
Craig.tridentms@gmail.com
EvoXDD is offline   Reply With Quote
Old 09-23-2012, 10:55 AM   #13
EvoXDD
Originally Posted by jdzumwalt View Post
Not taking this motor over 4k for the first 1000 miles make no sense. Don't beat on it but the motor needs to be ran through it's RPM range and varying degrees of load. If you don't do this Engines can have a bad Ring seal. IE excessive blow by.
Gregg
while this used to be true it is not anymore. they take care of that before the engine is even installed in the car, but i will agree that 1000 miles is a little to long for a break in.
Old 09-23-2012, 04:34 PM   #14
jdzumwalt
Motor Sports slut
I know for fact that most motor cycles are ran right up to redline before delivery from the factory. Not sure about all Car Motor's. I have built a few Complete race motor's and have never had any failures from revving them too early.
I did however have a motor somebody built me back in 2001 and they did a horrible job that motor never did seal right.
I say drive it like you would everyday and it should last 150k plus.
Gregg
What ENGINE OIL do they use for the 86/BRZ???? Funky Fresh AUSTRALIA 12 11-06-2012 12:23 AM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
Subaru BRZ engine + tranny into WRX body = RWD wagon ? MRZ415 Other Vehicles & General Automotive Discussions 6 07-22-2012 11:37 PM
What will the engine need to go FI? suprachica79 Engine, Exhaust, Transmission 90 11-29-2011 11:46 PM
FT 86 Engine jayjayjayjay Engine, Exhaust, Transmission 15 01-18-2011 02:22 PM
