Old 02-20-2012, 10:48 PM   #1
alex05
Drives: Celica GTS
Engine Question
Hello everyone,
Noob question. Does the ft86 have a Vtec or VVTL-i feature, where it "kicks in" after a certain RPM.
alex05 is offline   Reply With Quote
Old 02-20-2012, 10:54 PM   #2
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
The Zx6 comes with Subaru's DAVCS, but no it is not like vtec or VVTL-i which has variable lift properties.
If you would like to learn more please use the search function.
Welcome to the forum, and please take the time to introduce yourself in the new members thread.
WingsofWar is offline   Reply With Quote
Old 02-20-2012, 11:48 PM   #3
ahausheer
Re-member
Drives: Toyota camry
Originally Posted by alex05 View Post
Hello everyone,
You may also want to search the web for toyotas variable intake system. It has not been proven that it will be used in the BRZ/FR-S but you may perhaps find it interesting. It may also explain the torque curve for this car.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 02-21-2012, 12:54 AM   #4
Exage
GL 86!
Exage's Avatar
Drives: Maybe FR-S... maybe not
Hello
No
Apart from Honda, you most likely won't be seeing a stage cam shift again in engine development. Even so the cam switch point is so mediocre now they give you a light to tell you that "VTEC just kicked in yo" (12 Civic Si).
BMW and others have variable valve lift mechanisms in which they can control an engine based on valve lift then a throttle plate. Fiat's Multi-Air is another unique variable lift design currently adopted to intake valves. In the coming years expect more systems of the like to be implemented by companies including Honda.
For visual learners:
[u2b]5IrPcmMHqHE[/u2b]
If it's choppy switch to 360p
[u2b]BWsRSfe7K4M[/u2b]
Exage is offline   Reply With Quote
Old 02-21-2012, 06:08 AM   #5
serialk11r
Drives: '06 AM V8V Coupe
For high rev engines apparently fully variable lift/duration mechanisms cause a lot of stress and friction, so it's possible that a 2 stage lift system appears again. However with the advent of direct injection, the benefits are reduced, so I predict we'll see manufacturers go all or nothing: a variable geometry cam lobe rather than intermediate rockers, like Ferrari, or just a single cam with phasing, which apparently works fine on the LFA.
Question jay4prez Off-Topic Lounge [WARNING: NO POLITICS] 9 10-23-2020 11:31 AM
Question about the nomenclature.. RadOnc Scion FR-S / Toyota 86 GT86 General Forum 46 12-14-2013 11:55 PM
Headlight Swap Question nogaroblues4 Scion FR-S / Toyota 86 GT86 General Forum 9 02-07-2012 02:45 AM
Wheels Question Tsinoy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 01-19-2012 01:45 AM
