Old 10-29-2013, 06:30 PM   #1
Pneub
Drives: Dark Grey BRZ
Boost gauge not reading correctly
I've got a P3Cars Vent gauge, and while I'm mostly using it to keep track of my oil temps, I've noticed the boost seems to be reading incorrectly. At idle I'm between -18 and -21, which seems about right, but at full boost it's only reading at 4psi when I'm actually boosting about 9. Since it's going through my OBDII I'm not sure why it would be reading so low. What am I missing (probably a lot)?
Pneub is offline   Reply With Quote
Old 10-29-2013, 06:35 PM   #2
Are you using the stock sensors? It may be maxing out
Old 10-29-2013, 06:38 PM   #3
Pneub
Yes I am but I haven't heard about needing to change the sensors before. Other people with boosted 86s using the same gauge haven't mentioned it. Would I just change my MAF?
Old 10-29-2013, 06:39 PM   #4
xjohnx
Grip>Slip
xjohnx's Avatar
You need to change your MAP sensor (and get a reflash to accommodate that sensor).
The Following 3 Users Say Thank You to xjohnx For This Useful Post:
CSG Mike (10-29-2013), gdrider77 (10-29-2013), Pneub (10-29-2013)
Old 10-29-2013, 06:42 PM   #5
Pneub
Thanks. So does that mean the stock sensor just doesn't read past 4psi?
Old 10-29-2013, 06:58 PM   #6
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
i thought it was 7psi
Old 10-29-2013, 07:01 PM   #7
jamesm
i got about 5.3psi out of my stock one.
Old 10-29-2013, 07:10 PM   #8
xjohnx
Grip>Slip
xjohnx's Avatar
i believe it's 5.3, but only if your tuner expands the scaling to go that high.
The Following 2 Users Say Thank You to xjohnx For This Useful Post:
King Tut (10-29-2013), Pneub (10-29-2013)
Old 10-29-2013, 07:14 PM   #9
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
This. Also remember that if you do get a different MAP sensor, your tuner needs to adjust the scaling for it or your car might not run.
The Following User Says Thank You to King Tut For This Useful Post:
Cal3000 (10-30-2013)
Old 10-29-2013, 09:11 PM   #10
Pneub
Good to know. Thank you guys for all the help again.
Old 10-30-2013, 11:15 AM   #11
bgibbsunc
bgibbsunc's Avatar
Drives: Firestorm Scion FR-S
I also thought the stock would read up to seven. That is where all the tuners say you will need a map sensor to go higher. Well either way good to know.
FA20 club 60 trim + flex fuel
467 whp 356 ft lbs @ 19 lbs
Owner of Sidewinders Auto LLC.
San Antonio TX
bgibbsunc is offline   Reply With Quote
Old 10-30-2013, 12:39 PM   #12
Cal3000
Drives: Panda FR-S
This. I have a 3BAR sensor in my car, but my boost readings through ECUtek data log reads a max of about 4psi. My car still runs though.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
boost, gauge, p3cars
boost gauge vortech help ft86me Forced Induction 47 07-06-2015 10:50 AM
Fuel gauge not reading properly FR-S Hot Lava Issues | Warranty | Recalls / TSB 27 10-29-2014 10:33 AM
Boost gauge off at elevation gdrider77 Forced Induction 7 09-25-2013 01:32 PM
Boost and mixture gauge questions mike the snake Forced Induction 9 07-29-2013 07:55 PM
Which boost gauge? Bigmaxy Forced Induction 3 07-07-2013 07:11 PM
