Old 09-24-2013, 06:00 PM   #1
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Boost gauge off at elevation
So was just thinking about this, i am in denver, so elevation of 5280. Would my AEM boost gauge be off a couple psi due to the elevation?
Anyone else at elevation show their gauge being 2 psi less? I was originally thinking i have the wrong actuator, but now i am thinking that maybe my 8psi actuator is only reading at 6psi due to elevation.
Can i check with ecutek logs somehow to see the "trueboost"? Or possibly with torque?
Just trying to iron out some issues.
Thoughts?
gdrider77 is offline   Reply With Quote
Old 09-24-2013, 09:09 PM   #2
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
Boost gauge will not be off, but to be sure use the bar reading ecutek puts out
448hpsti is offline   Reply With Quote
Old 09-24-2013, 09:13 PM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Thoughts?
ECUtek and Torque will display the same MAP sensor reading. You can try either against your Boost gauge.
Old 09-24-2013, 10:55 PM   #4
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Atmospheric pressure at sea level is about 14.7 psi.
Atmospheric pressure at Denver International airport is about 12 psi.
The wastegate in a turbo system raises boost pressure above local atmospheric pressure. So 8 psi boost at sea level is going to be higher absolute pressure than 8 psi in Denver.
If your boost gauge is calibrated to read 0 when it's reading atmospheric pressure in Denver, then you should see 8 psi on your gauge at full boost. If it's calibrated to read 0 at sea level, then you should see it hanging around 4-5" vacuum with your car off, and it might get up to 6 psi at full boost.
Sellout is offline   Reply With Quote
Old 09-25-2013, 10:55 AM   #5
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Thoughts?
The AEM boost gauge is the only one I know of that calibrates itself every time you turn the car on to the local atmosphere. My AEM failsafe doesn't do it, but in my buddies STi for his AEM Truboost gauge to read accurately you have to turn the car on but not start it and allow it to do it's calibration to zero boost/vacuum and then start the car. What does your gauge show as vacuum with the A/C off and at idle?
Old 09-25-2013, 12:34 PM   #6
jamesm
my prosport gauge said it came calibrated for 1000ft elevation, a compromise i guess. seemed weird to me at the time, but it seems to read perfectly well in line with the map.
Old 09-25-2013, 01:17 PM   #7
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I think most boost gauges are setup this way. They are set from the factory with some elevation to be zero boost/vacuum.
Old 09-25-2013, 01:32 PM   #8
fenton
Its also harder to boost at higher altitudes.
When i had my STI at +3500 feet target redline boost was suposse to be 13.5psi but i only ever saw 11.8 to 12.2.
fenton is offline   Reply With Quote
DIY - Defi 60mm Boost Gauge Install in AC Vent msile DIY (Do-It-Yourself) Guides 55 02-27-2016 01:10 PM
boost gauge vortech help ft86me Forced Induction 47 07-06-2015 10:50 AM
Boost and mixture gauge questions mike the snake Forced Induction 9 07-29-2013 07:55 PM
Which boost gauge? Bigmaxy Forced Induction 3 07-07-2013 07:11 PM
Memorial Deal!!White MaxTow 30 PSI Boost/Vacuum Gauge Tubano-shop Interior Parts (Incl. Lighting) 0 05-27-2013 07:47 AM
