Old 07-19-2013, 09:48 PM   #1
ft86me
ft86me's Avatar
Drives: 2013 FRS
boost gauge vortech help
put in an aem boost gauge today and it is reading mostly vacuum only and under WOP it reads 0. I checked to see if I am boosting through data logs and I am boosting close to 10 at red.
There is a T in the brake booster line which one hose goes to the bypass valve. I T'd off onto the hose that is going to the bypass valve and here i am with my issue.
ideas/solutions please.
ft86me is offline   Reply With Quote
Old 07-20-2013, 12:36 AM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The only guess I have is that you are tapping into a hose after a check valve that is not allowing the gauge to see boost.
Old 07-20-2013, 12:45 AM   #3
ft86me
ft86me's Avatar
Drives: 2013 FRS
So would you recommend that I tap into the pipe coming from the throttle body with a barb?
Old 07-20-2013, 01:05 AM   #4
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Get a vacuum manifold send the signal from the brake booster there, and distribute accessories from the manifold, including the gauge.
Old 07-20-2013, 01:06 AM   #5
ft86me
ft86me's Avatar
Drives: 2013 FRS
Update:
According to
Chargred86 I rerouted.
From brake booster t that vortech supplied I put the aem boost gauge hose to it. Then teed off the boost gauge hose and put the boost gauge to the new t fitting.
Boost now shows higher numbers up in higher rpms under load. Still feels like it's not showing right numbers. At about 50 percent throttle the boost is at 0
Old 07-20-2013, 01:07 AM   #6
ft86me
ft86me's Avatar
Drives: 2013 FRS
I'm not following what you're trying to say. Bare w me I'm not knowledgable bout doing this
Old 07-20-2013, 01:12 AM   #7
Sportsguy83
Drives: Limited BRZ
Well, maybe you can fix it easier than what I said.
Going into more detail, using a [ame="http://www.amazon.com/automotive/dp/B0018033OQ"]Vacuum manifold[/ame], you would have just teed off the brake booster line, and then use all ports provided by the manifold to provide boost signal to AEM gauge, pressure relief valve and any other components that need boost signal. that way you prevent having to do a number of tees in order to get your boost signal to all components.
Old 07-20-2013, 01:16 AM   #8
ft86me
ft86me's Avatar
Drives: 2013 FRS
Going into more detail, using a Vacuum manifold, you would have just teed off the brake booster line, and then use all ports provided by the manifold to provide boost signal to AEM gauge, pressure relief valve and any other components that need boost signal. that way you prevent having to do a number of tees in order to get your boost signal to all components.
Oh I see what you're saying! I'd like to stay away from purchasing that item. Ugh frustrating. I have no boost leaks too
Old 07-20-2013, 09:14 PM   #9
King Tut
NASA SpecE30 Racer
King Tut's Avatar
If you are seeing any boost on it at all, then it is most likely working properly. What is the max number you see at Wide Open Throttle (WOT)?
Old 07-20-2013, 09:20 PM   #10
ft86me
ft86me's Avatar
Drives: 2013 FRS
I got 9 at red so i guess I'm good!
Old 07-21-2013, 09:37 AM   #11
wparsons
wparsons's Avatar
How does the recirc/venting work on the vortech? Does it only build boost under WOT conditions, or will it build partial boost at part throttle?
flickr
Old 07-21-2013, 10:01 AM   #12
sw20kosh
Drives: 2013 Black FR-S
Should be a simple bypass: Under vacuum the valve is open. When there is much less vacuum or 0 vacuum it closes.
Old 07-21-2013, 10:11 AM   #13
Foobar
SLO NO MO
Foobar's Avatar
Update:
According to
The bypass valve doesn't completely close until you go WOT. Until that happens, boost is bypassed to avoid parasitic loss. You've probably noticed the sound of air venting out until you slam the gas, and then it goes away - that's what's happening here.
Old 05-08-2014, 03:09 PM   #14
FyeaFRS
Drives: 1992 Nissan Skyline GTS-t Type-M
Would someone post a picture of this setup? I was about to connect my auto meter vacuum/boost gauge how ft86me originally had their's, but I guess it didn't work..?
FyeaFRS is offline   Reply With Quote
Vortech Supercharging System Update - More boost, more POWER! Brian@Vortech Forced Induction 337 03-12-2016 03:42 PM
DIY - Defi 60mm Boost Gauge Install in AC Vent msile DIY (Do-It-Yourself) Guides 55 02-27-2016 01:10 PM
Which boost gauge? Bigmaxy Forced Induction 3 07-07-2013 07:11 PM
Memorial Deal!!White MaxTow 30 PSI Boost/Vacuum Gauge Tubano-shop Interior Parts (Incl. Lighting) 0 05-27-2013 07:47 AM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 04:29 PM
