Drives: Dark Grey BRZ
Boost gauge not reading correctly
I've got a P3Cars Vent gauge, and while I'm mostly using it to keep track of my oil temps, I've noticed the boost seems to be reading incorrectly. At idle I'm between -18 and -21, which seems about right, but at full boost it's only reading at 4psi when I'm actually boosting about 9. Since it's going through my OBDII I'm not sure why it would be reading so low. What am I missing (probably a lot)?
#2 |
Are you using the stock sensors? It may be maxing out
#3 |
Yes I am but I haven't heard about needing to change the sensors before. Other people with boosted 86s using the same gauge haven't mentioned it. Would I just change my MAF?
#4 |
Grip>Slip
#5 |
Thanks. So does that mean the stock sensor just doesn't read past 4psi?
#6 |
Boosted
Drives: Not a supra....yet
#7 |
i got about 5.3psi out of my stock one.
#8 |
Grip>Slip
i believe it's 5.3, but only if your tuner expands the scaling to go that high.
#9 |
NASA SpecE30 Racer
This. Also remember that if you do get a different MAP sensor, your tuner needs to adjust the scaling for it or your car might not run.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | Cal3000 (10-30-2013) |
#10 | |
Good to know. Thank you guys for all the help again.
#11 |
Drives: Firestorm Scion FR-S
I also thought the stock would read up to seven. That is where all the tuners say you will need a map sensor to go higher. Well either way good to know.
FA20 club 60 trim + flex fuel 467 whp 356 ft lbs @ 19 lbs Owner of Sidewinders Auto LLC. San Antonio TX |
#12 |
Drives: Panda FR-S
This. I have a 3BAR sensor in my car, but my boost readings through ECUtek data log reads a max of about 4psi. My car still runs though.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
![]() 242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
| Tags |
| boost, gauge, p3cars |
| boost gauge vortech help | ft86me | Forced Induction | 47 | 07-06-2015 10:50 AM |
| Fuel gauge not reading properly | FR-S Hot Lava | Issues | Warranty | Recalls / TSB | 27 | 10-29-2014 10:33 AM |
| Boost gauge off at elevation | gdrider77 | Forced Induction | 7 | 09-25-2013 01:32 PM |
| Boost and mixture gauge questions | mike the snake | Forced Induction | 9 | 07-29-2013 07:55 PM |
| Which boost gauge? | Bigmaxy | Forced Induction | 3 | 07-07-2013 07:11 PM |
