Old 07-27-2013, 09:57 PM   #1
mike the snake
Boost and mixture gauge questions
I just traded my BMW 135i in for my new BRZ, and on that car I had a very cool chip tune that gave me a bunch of power AND, a few other cool options.
The tunes available (Vishnu Procede and Burger Motorsports JB4) had options that changed the fuel and oil temp gauges into Boost and Mixture gauges. When activated, the fuel gauge acted as a boost gauge, with 1/2 tank being 10 pounds. The temp gauge could also be changed to a mixture gauge with the 1/2 point on the gauge being stoich.
Is it possible for these options to be applied on our FRS and BRZ cars?
Seems that if so, it could save a few bucks on an already expensive venture.
Both these options on my 135i were super easy to read and very accurate.
Old 07-27-2013, 10:03 PM   #2
xjohnx
Grip>Slip
xjohnx's Avatar
i know ECUtek and @Visconti experimented with repurposing some of the OEM gauges in the past but it caused some other bugs if i recall. I'd LOVE the OEM analog speedometer to be repurposed into a boost or oil temp gauge. Or better yet if they could find a way to make it function as a display for a wideband o2 that would be huge. I'm sure i'm dreaming on that one though.
Old 07-27-2013, 10:18 PM   #3
mike the snake
That would be very cool!
I know on my 135i it was SUPER easy to read and understand the boost and mixtures, the 1/2 points on the gauges were 10 pounds and stoich.
Old 07-27-2013, 10:20 PM   #4
xjohnx
Grip>Slip
xjohnx's Avatar
Then again, coming from the BMW world, some BMW tuners who work closely with vishnu are releasing a product called OpenFlash Tablet for the BRZ. It was just released for the BMW a couple weeks back if I recall correctly. Perhaps @Rombinhood@OpenFlash can comment.
Old 07-29-2013, 10:55 AM   #5
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The latest EcuTek versions use the tach as a percentage of flash complete kind of, so I know they can control the gauges. With that being said, if you want to see those things then just add a display and run something like Torque or get the P3 gauge.
Old 07-29-2013, 11:34 AM   #6
xjohnx
Grip>Slip
xjohnx's Avatar
I think he was looking for a way to implement it with already existing equipment to save a few bucks (if possible).
The analog speedo is a perfect example of something that could be repurposed as a functional AF, boost or oil temp gauge. I've owned my car for over a year now and I can't recall ever looking at the analog speedo.
Another cool feature that I've mentioned to John V. would be if they could integrate a knock detection light on the dashboard (maybe by flashing one of the lights on the dash, whether it be CEL, high beam light, ABS light, whatever.) I'm not sure how much of this is technically possible, but would definitely be a cool addition and could be a good feature/selling point for ECUtek or OpenFlash Tablet if they were to incorporate something like that.
Old 07-29-2013, 12:05 PM   #7
jamesm
yeah the analog speedo is a waste of space on this car. unfortunately 0-160 isn't a really good scale to present anything else useful with it. any ideas?
Old 07-29-2013, 06:32 PM   #8
mike the snake
I would think 0-160 analog speedo would be perfect for a boost gauge. Each 1000rpm would be 1 pound of boost.
Old 07-29-2013, 06:52 PM   #9
King Tut
NASA SpecE30 Racer
King Tut's Avatar
0 to 160 would be perfect for oil temps in degrees Celcius.
Old 07-29-2013, 07:55 PM   #10
xjohnx
Grip>Slip
xjohnx's Avatar
Would be perfect for an Oil Temp gauge, just read off the KMH scale, goes up to 260.
DIY - Defi 60mm Boost Gauge Install in AC Vent msile DIY (Do-It-Yourself) Guides 55 02-27-2016 01:10 PM
boost gauge vortech help ft86me Forced Induction 47 07-06-2015 10:50 AM
Which boost gauge? Bigmaxy Forced Induction 3 07-07-2013 07:11 PM
Memorial Deal!!White MaxTow 30 PSI Boost/Vacuum Gauge Tubano-shop Interior Parts (Incl. Lighting) 0 05-27-2013 07:47 AM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 04:29 PM
