Drives: Panda FR-S
Help! Vortech SC oil drain tubing destroyed!
Apparently I incorrectly mounted the oil drain tubing and it resulted in rubbing against the crank pulley creating a hole in the tubing. It's leaking everywhere. Is there a way to repair the stainless steel flexible hose?
Does anyone know the tubing size? I want to cut away the damaged section and couple the tubing. Where can I get the stainless tubing? I'm stranded. No oil in the SC. Any help will be great. Thanks!
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
![]() 242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
Drives: Scion FR-S
I think I just spoke to you on the phone! :P
| The Following User Says Thank You to Rick@Vortech For This Useful Post: | Cal3000 (10-21-2013) |
#3 | |
SLO NO MO
| The Following User Says Thank You to Foobar For This Useful Post: | Cal3000 (10-21-2013) |
Drives: Panda FR-S
Oh it was you :P
Thanks! Hopefully I can get the hosing by tomorrow. I just checked the oil and it is at the half way mark. I was expecting it all to leak out last night. Also I found out I have about 1 to 2 oz of fluid left over. If I bend and pinch the hose, that should keep the fluid from leaking?
| The Following User Says Thank You to Cal3000 For This Useful Post: | pheoxs (10-21-2013) |
#5 | |
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
I'm assuming the drain line screws into the supercharger. If the size of that port is the same size as the vent port. Could you not drain your supercharger, and install the shipping plug into the drain port to block it off?
Nolan
| The Following User Says Thank You to pheoxs For This Useful Post: | Cal3000 (10-21-2013) |
#6 | |
Drives: Panda FR-S
#7 | |
Thupercharged
I personally would park it until fixed, losing your SC oil and running it dry at multiple speeds faster than your engine RPM sounds like a bad time
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
Drives: Panda FR-S
Anyone know the size of the oil drain tubing?
@Rick@Vortech It does not look like you guys updated your documentation yet to cover some of these types of things yet?
| Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? | tracerit | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 01-04-2016 07:36 PM |
| I think I destroyed my ABS sensor. | ML | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 09-15-2013 07:46 PM |
| Forced induction tubing | UMB FR-S | Forced Induction | 5 | 06-24-2013 02:35 PM |
| MT fill and drain washers | diirk | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 10 | 11-09-2012 12:24 AM |
| aftermarket rubber intake tubing??? | 20valvewynn83 | Southern California | 39 | 09-13-2012 11:12 PM |
