Old 10-21-2013, 01:58 AM   #1
Cal3000
Drives: Panda FR-S
Help! Vortech SC oil drain tubing destroyed!
Apparently I incorrectly mounted the oil drain tubing and it resulted in rubbing against the crank pulley creating a hole in the tubing. It's leaking everywhere. Is there a way to repair the stainless steel flexible hose?
Does anyone know the tubing size? I want to cut away the damaged section and couple the tubing. Where can I get the stainless tubing?
I'm stranded. No oil in the SC. Any help will be great. Thanks!
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 10-21-2013, 11:18 AM   #2
Rick@Vortech
Drives: Scion FR-S
I think I just spoke to you on the phone! :P
Rick@Vortech is offline   Reply With Quote
The Following User Says Thank You to Rick@Vortech For This Useful Post:
Cal3000 (10-21-2013)
Old 10-21-2013, 11:18 AM   #3
Foobar
SLO NO MO
Foobar's Avatar
Did you try reaching out to Vortech? I'd be surprised if they can't sell you the flex hose.
The Following User Says Thank You to Foobar For This Useful Post:
Old 10-21-2013, 11:33 AM   #4
Cal3000
Drives: Panda FR-S
Oh it was you :P
Thanks! Hopefully I can get the hosing by tomorrow. I just checked the oil and it is at the half way mark. I was expecting it all to leak out last night. Also I found out I have about 1 to 2 oz of fluid left over. If I bend and pinch the hose, that should keep the fluid from leaking?
The Following User Says Thank You to Cal3000 For This Useful Post:
pheoxs (10-21-2013)
Old 10-21-2013, 11:37 AM   #5
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Oh it was you :P
I'm not at home and thus can't look mine but maybe @Rick@Vortech can answer this as a solution in a pinch.
I'm assuming the drain line screws into the supercharger. If the size of that port is the same size as the vent port. Could you not drain your supercharger, and install the shipping plug into the drain port to block it off?
Nolan
pheoxs is offline   Reply With Quote
The Following User Says Thank You to pheoxs For This Useful Post:
Old 10-21-2013, 12:32 PM   #6
Cal3000
Drives: Panda FR-S
Yeah. It screws in. Problem is the only way to get to the drain line connected to the SC is to pull the blower. That's going to be a pain. For now, I pinched the line. The line is rubber tubing wrapped with stainless steel braids I think. If the rubber pinches fully, it should be able to stop the fluid flow at the pinch. The line is very low pressure. At idle anyways. Less than 1psi it seems. I don't know for higher speeds though.
Old 10-21-2013, 02:30 PM   #7
DJCarbine
Thupercharged
DJCarbine's Avatar
I think that depends on how much heat you generate in the blower and how the blower venting system works (I have not looked into it but there is a vent built into one of the fittings on top)
I personally would park it until fixed, losing your SC oil and running it dry at multiple speeds faster than your engine RPM sounds like a bad time
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 10-23-2013, 02:58 AM   #8
Cal3000
Drives: Panda FR-S
Anyone know the size of the oil drain tubing?
Old 10-24-2013, 01:24 AM   #9
Dezoris
Dezoris's Avatar
@Rick@Vortech It does not look like you guys updated your documentation yet to cover some of these types of things yet?
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 07:36 PM
I think I destroyed my ABS sensor. ML Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 09-15-2013 07:46 PM
Forced induction tubing UMB FR-S Forced Induction 5 06-24-2013 02:35 PM
MT fill and drain washers diirk Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 11-09-2012 12:24 AM
aftermarket rubber intake tubing??? 20valvewynn83 Southern California 39 09-13-2012 11:12 PM
