Old 09-15-2013, 02:00 PM   #1
ML
ML's Avatar
Drives: 13 White MT FR-S
I think I destroyed my ABS sensor.
I took the hub off my front left to replace the wheel studs. Finished, and mounted everything back up only to be greeted by the ABS light on the console. Jacked it back up and found this on the inside of the wheel knuckle(?). Is this the sensor for the ABS?
Old 09-15-2013, 07:33 PM   #2
ML
ML's Avatar
I think I figured out where this is from....
Should be easy to fix? Buy new one, pull old one out, pop new one in?
Old 09-15-2013, 07:43 PM   #3
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Sit down before you ask how much these puppies cost.
Suberman is offline   Reply With Quote
Old 09-15-2013, 07:46 PM   #4
ML
ML's Avatar
$44.95
http://www.ebay.com/itm/13-2013-SCIO...353c48&vxp=mtr
O2 Sensor ? grostoine Engine, Exhaust, Transmission 4 02-21-2016 10:20 PM
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 02:20 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
02 Sensor mjsivee Engine, Exhaust, Transmission 4 06-13-2013 01:58 PM
Bad MAF Sensor paulieblaze Scion FR-S / Toyota 86 GT86 General Forum 3 08-23-2012 10:34 PM
