Old 11-08-2012, 07:58 PM   #1
diirk
diirk's Avatar
Drives: 4Runner
MT fill and drain washers
Was at Toyota today. Checked the price and I was told the washers are $17/ea.
Is there an alternative?
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 11-08-2012, 08:07 PM   #2
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
Yes, don't buy them. You don't really need to change them, at least not the first few times you take them out. As long as the hole doesn't leak you are good to go, and it is very easy to torque the drain and fill bolts nice and tight.
No Limit Motorsport is offline   Reply With Quote
Old 11-08-2012, 08:12 PM   #3
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
These suckers are pricey but they can be had for less. I bought mine from subarugenuineparts.com
They are $6.30 each, P/N 17008AA050...need two as both fill and drain use same washer.
Mind you there is a shipping charge but I did it this way as it was much easier than going to my dealer over 50 miles away.
As long as we are talking drain/fill washers. The rear differential washers are:
Fill plug washer: 11126JB000-$1.38 each
Drain plug washer: 1215710010-$1.58 each
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Old 11-08-2012, 08:18 PM   #4
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
Haven't messed with mine yet, but do our cars even have true crush washers?
On a semi-related note, I wonder if the vast majority of dealers bother changing these during service...
The Following User _________ Stay_Puft(09-13-2014)
Says Thank You to
MmmHamSandwich For
This Useful Post:
MmmHamSandwich is offline   Reply With Quote
Old 11-08-2012, 08:45 PM   #5
diirk
diirk's Avatar
Drives: 4Runner
Excellent info. Thanks. I usually buy parts online, but happened to be at the dealership today with some time to kill, so i thought I'd check it out.
FYI, the diff washers ar $4/ea at the dealership and the crash bolts are $14/ea.
diirk
Old 11-08-2012, 10:05 PM   #6
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
Just flip them before you put the plugs back in, torque to spec and you'll be fine.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 11-08-2012, 10:06 PM   #7
ArKiTeCkT
ArKiTeCkT's Avatar
Drives: 2010 Gen Coupe, 2013 BRZ 6MT S.Tech
^ I got mine for 1.50 each
ArKiTeCkT is offline   Reply With Quote
Old 11-08-2012, 10:35 PM   #8
Ryan1JZ
Drives: AE93, JZZ30, ZN6
cant you just take the washer to an auto store and get a generic one in the equivalent size?
Ryan1JZ is offline   Reply With Quote
Old 11-08-2012, 10:40 PM   #9
Jidonsu
Drives: Scion FR-S | 6MT | Ultramarine
Just call ahead to the local Subaru dealership. If they don't have it, they will order. You shouldn't even have to pay for the shipping from the distribution center to the dealer. Just go pick them up when they're in.
Jidonsu is offline   Reply With Quote
Old 11-08-2012, 11:16 PM   #10
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
I work at a shop and you should never re use trans and diff seal washers they are usually one time use items. if youre smart pay for the best deal on new ones and use them. being cheap can cause a ton more problems in the long run do it right the first time and it can mean a world of difference. trust me. imagine it doesnt seal perfectly and slowly slowly you start losing bits of trans fluid till its gone and you didnt know. one day driving your trans just melts from friction then youre out a transmission no good.
just giving my advice :-)
DanoFA20 is offline   Reply With Quote
Old 11-09-2012, 12:24 AM   #11
Dezoris
Dezoris's Avatar
I re-used my old ones mainly because its 27lbs of TQ. Not going to crush them with that pressure.
Factory Oil Fill Level Black Tire Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 54 12-09-2016 01:14 AM
Loss power after gas fill up HELP! Ad8707 Issues | Warranty | Recalls / TSB 63 08-21-2014 01:01 AM
New 8" Alpine fill the stock opening? Roborat Electronics | Audio | NAV | Infotainment 3 08-20-2012 07:43 PM
Engine oil drain plug washer BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 06-28-2012 11:28 AM
How much are you guys paying to fill your tanks? Giccin Off-Topic Lounge [WARNING: NO POLITICS] 64 04-13-2011 01:36 AM
