Drives: Asphalt FRS
Oil Change
Stupid question, but I just changed my oil. I put 6 qts in, forgetting that there's a 5.5 qt requirement. Would I be best to drain excess oil out of the engine, or am I safe to drive with the full 6qts in the car?
Thanks in advance! |
Drives: '13 BRZ / '11 Outback / '06 Tundra
no issues with 6 quarts.
Drives: SWP BRZ Limited MT
Probably not, 6qts should be still okay, as long as it's not overflowing, check your engine oil metering stick.
Drives: Asphalt FRS
No overflow, was mildly concerned but no drivability issues so I guess I can assume its safe.
Mentat
Drives: 2013 Scion FRS 6MT
I would not exceed the limit. Too much oil can cause foaming effect and that is pretty bad for the motor.
Drives: '13 Ultramarine
If you're only over a bit (I think the spec is 5.8 with a filter change), and it bothers you at all, just grab another filter and change it. That should be roughly the right amount of oil to remove. Re-start the car, shut it off, and wait for a few minutes to check the oil (these engines seem to take a bit of time to drain back into the pan). You'll probably find that it is just a hair under the "full". Perfect.
Drives: 2019 Mazda Miata RF
Pulling that filter off is going to be a mess.
#8 | |
Drives: Subaru BRZ Sport Tech Satin White
It is extremely important to run the oil level no higher than maximum on the dipstick. Once the crank starts hitting the oil surface you will have problems. |
| DIY BRZ / FR-S Oil Change | RallySport Direct | DIY (Do-It-Yourself) Guides | 169 | 09-01-2018 02:42 AM |
| Should I change my oil? | retrosmiths | Tracking / Autocross / HPDE / Drifting | 9 | 08-06-2013 11:36 AM |
| Oil Change | 86 FRS | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 01-18-2013 10:00 AM |
| First Oil Change | Jehuty77 | CANADA | 14 | 08-09-2012 11:54 PM |
| When to do your first oil change, and why... | MrBodyMassage | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 07-17-2012 07:43 PM |
