Drives: Scion FR-S Whiteout
Should I change my oil?
Running factory oil and filter.
Went to a "drift practice" event (86 Dynamic Driving to be exact) at around 3,500 miles. This was last month. Car is now at 4,800 miles. Going to another event this Aug 10th. Should I change the oil afterwards or before? I'll also be taking it to the dealer at 7,500.
2013 Scion FR-S
Is this the oil that the car originally came with?
dying bird under the hood
Drives: 2013 SWP Limited BRZ
You should be fine if you had it changed at 3k
Grip>Drift
Drives: FRS
If it's never been changed I would do so before next event then again at 7.5K miles.
| The Following User Says Thank You to BlaineWasHere For This Useful Post: | CSG Mike (08-05-2013) |
It's never been replaced.
2013 Scion FR-S
Track Junkie
Drives: White FR-S
Easy Litmus test - Do you have enough money in the bank for a new motor? Yes? Keep the oil until the scheduled change. No? Change the oil.
-Scott
#7 | |
I can't order from ft86speedfactory because there's no guarantee it will arrive on my doorstep on Friday.
2013 Scion FR-S
Grip>Drift
Drives: FRS
Get the filter from a Subaru dealer. Pretty much the cheapest I've found.
Buy a Honda S2000 filter. You can drop by and pick up some Motul from us.
| The Following User Says Thank You to CSG Mike For This Useful Post: | retrosmiths (08-06-2013) |
#10 |
Thanks guys, I actually just realized I can drop by Evasive Motorsports since it's near my place. As much as I'd like to do the oil change my own, I have no time for it right now.
2013 Scion FR-S
| DIY BRZ / FR-S Oil Change | RallySport Direct | DIY (Do-It-Yourself) Guides | 169 | 09-01-2018 02:42 AM |
| First oil change....ever. | Ayaz2589 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 21 | 04-12-2013 03:50 PM |
| 3,000 mi oil-change | prest1ge | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 38 | 10-29-2012 07:13 PM |
| When to change the oil | Capstan | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 10-11-2012 02:41 PM |
| When to do your first oil change, and why... | MrBodyMassage | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 07-17-2012 07:43 PM |
