Old 03-29-2013, 10:09 AM   #1
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
Toe Link Install problems
Trying to install toe links on the rear but im having trouble removing them from the knuckle(?) , any idea how to get them out? tried banging them out, using a puller and it wont budge. the "toe bolt" comes out fine
SLICVIC is offline   Reply With Quote
Old 03-29-2013, 11:41 AM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
You might need a pickle fork.
Old 03-29-2013, 11:46 AM   #3
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
Looks like it might be it, ill check into that . Thanks
Old 03-29-2013, 02:25 PM   #4
Hancha Group
FT86Club Official Vendor
Hancha Group's Avatar
Drives: Subarus
Hit the knuckle sideways so you're transmitting the force at a 90 degree angle from the ball joint. If you keep hitting it on the stud, you can mushroom the threads.
Hancha Group is offline   Reply With Quote
Old 03-29-2013, 02:52 PM   #5
Calum
That Guy
Good thought.
Another easy way to avoid mushrooming the threads is to put the nut on a little proud, and hit the nut.
Old 03-29-2013, 03:31 PM   #6
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
lol tried the hitting the nut and fucked up the threads on the nut. picked up a pickle fork as @Calum suggested and worked like a charm. you sir are a noble gentlemen.
Old 03-29-2013, 04:38 PM   #7
Calum
That Guy
Why thank you, sir.
Glad you got it worked out.
Old 03-29-2013, 04:41 PM   #8
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Originally Posted by Calum View Post
Why thank you, sir.
Too much nice conversation in a thread
Why cant it always go like this?
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 03-29-2013, 05:48 PM   #9
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Good thought.
You must be better at this than me, I buggered up both bolt and nut using this method. I was however using a BFH when I prolly should been using a dead blow.
Them is in their tight.
Fork worked for me too
Huehuecoyotl is offline   Reply With Quote
Old 03-29-2013, 07:01 PM   #10
Hancha Group
Drives: Subarus
With a pickle fork, it's easy to tear the boot. Something to consider if you ever want to reuse or resell. If you hit the knuckle at a 90, after a minute or so, the ball joint will slide off and leaves the toe link in perfect condition.
Old 03-29-2013, 08:45 PM   #11
eckoflyte
Drives: Toyota 86 GTS
What sort of weight/length sledge would be most suitable?
eckoflyte is offline   Reply With Quote
Old 03-29-2013, 09:04 PM   #12
Hancha Group
Drives: Subarus
Not very big, 3 lb (1.5 kg) should be okay. It seems futile at first since you don't see it doing anything, but keep at it. Eventually, it'll slide right out.
Old 03-29-2013, 10:38 PM   #13
Calum
That Guy
I haven't done it with that particular stud, but I've done it more then a few times. Experience would tell me which method to use. Unfortunately I can't really pass that over the internet so I just wanted to give OP as many tools as possible to do the job.
Next time I might try a modified version of HG's idea by using an air hammer instead of a BFH. Should make things easier on the arms and the surronding mounting points. If the snow ever melts and I finally get under my car, I'll report my findings.
Sorry it didn't work out for you.
Old 03-29-2013, 10:47 PM   #14
Huehuecoyotl
Yes, been there done that too, that was before I decided to go pounding on the bolt!. So word to the next guy, if youre using a fork, careful. You can tell I dont do ball joint type work often, luckily for my cars.
I felt weird pouding on it with the bfh at the 90 degree angle after several blows, but youre saying stay with it, put in the ear plugs and whack-away, huh...will try that next time.Thanks for sure
Andriod Headunit with HKS OB-Link? stevo_12v Electronics | Audio | NAV | Infotainment 40 04-14-2013 03:31 AM
Hancha Rear Toe Link Hancha Group Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 04-05-2013 08:18 PM
STi Trailing Link Set - Released Beyer Subaru Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-16-2013 12:21 AM
Gearbox: Cable Link or Mechanical Link? Marrk BRZ First-Gen (2012+) — General Topics 42 07-01-2012 11:45 PM
