Old 03-29-2013, 11:09 AM   #1
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
Toe Link Install problems
Trying to install toe links on the rear but im having trouble removing them from the knuckle(?) , any idea how to get them out? tried banging them out, using a puller and it wont budge. the "toe bolt" comes out fine
SLICVIC is offline   Reply With Quote
Old 03-29-2013, 12:41 PM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
You might need a pickle fork.
Old 03-29-2013, 12:46 PM   #3
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
Looks like it might be it, ill check into that . Thanks
Old 03-29-2013, 03:25 PM   #4
Hancha Group
FT86Club Official Vendor
Hancha Group's Avatar
Drives: Subarus
Hit the knuckle sideways so you're transmitting the force at a 90 degree angle from the ball joint. If you keep hitting it on the stud, you can mushroom the threads.
Hancha Group is offline   Reply With Quote
The Following User Says Thank You to Hancha Group For This Useful Post:
Huehuecoyotl (03-29-2013)
Old 03-29-2013, 03:52 PM   #5
Calum
That Guy
Good thought.
Another easy way to avoid mushrooming the threads is to put the nut on a little proud, and hit the nut.
The Following User Says Thank You to Calum For This Useful Post:
SkullWorks (03-29-2013)
Old 03-29-2013, 04:31 PM   #6
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
lol tried the hitting the nut and fucked up the threads on the nut. picked up a pickle fork as @Calum suggested and worked like a charm. you sir are a noble gentlemen.
Old 03-29-2013, 05:38 PM   #7
Calum
That Guy
Why thank you, sir.
Glad you got it worked out.
Old 03-29-2013, 05:41 PM   #8
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Originally Posted by Calum View Post
Why thank you, sir.
Too much nice conversation in a thread
Why cant it always go like this?
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
The Following User Says Thank You to Tansey86 For This Useful Post:
SLICVIC (07-08-2013)
Old 03-29-2013, 06:48 PM   #9
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Good thought.
You must be better at this than me, I buggered up both bolt and nut using this method. I was however using a BFH when I prolly should been using a dead blow.
Them is in their tight.
Fork worked for me too
Huehuecoyotl is offline   Reply With Quote
Old 03-29-2013, 08:01 PM   #10
Hancha Group
Drives: Subarus
With a pickle fork, it's easy to tear the boot. Something to consider if you ever want to reuse or resell. If you hit the knuckle at a 90, after a minute or so, the ball joint will slide off and leaves the toe link in perfect condition.
Old 03-29-2013, 09:45 PM   #11
eckoflyte
Drives: Toyota 86 GTS
What sort of weight/length sledge would be most suitable?
eckoflyte is offline   Reply With Quote
Old 03-29-2013, 10:04 PM   #12
Hancha Group
Drives: Subarus
Not very big, 3 lb (1.5 kg) should be okay. It seems futile at first since you don't see it doing anything, but keep at it. Eventually, it'll slide right out.
Old 03-29-2013, 11:38 PM   #13
Calum
That Guy
I haven't done it with that particular stud, but I've done it more then a few times. Experience would tell me which method to use. Unfortunately I can't really pass that over the internet so I just wanted to give OP as many tools as possible to do the job.
Next time I might try a modified version of HG's idea by using an air hammer instead of a BFH. Should make things easier on the arms and the surronding mounting points. If the snow ever melts and I finally get under my car, I'll report my findings.
Sorry it didn't work out for you.
Old 03-29-2013, 11:47 PM   #14
Huehuecoyotl
Yes, been there done that too, that was before I decided to go pounding on the bolt!. So word to the next guy, if youre using a fork, careful. You can tell I dont do ball joint type work often, luckily for my cars.
I felt weird pouding on it with the bfh at the 90 degree angle after several blows, but youre saying stay with it, put in the ear plugs and whack-away, huh...will try that next time.Thanks for sure
Andriod Headunit with HKS OB-Link? stevo_12v Electronics | Audio | NAV | Infotainment 40 04-14-2013 04:31 AM
Hancha Rear Toe Link Hancha Group Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 04-05-2013 09:18 PM
STi Trailing Link Set - Released Beyer Subaru Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-16-2013 01:21 AM
Gearbox: Cable Link or Mechanical Link? Marrk BRZ First-Gen (2012+) — General Topics 42 07-02-2012 12:45 AM
