Drives: 2006 STi
Toe Link Install problems
Trying to install toe links on the rear but im having trouble removing them from the knuckle(?) , any idea how to get them out? tried banging them out, using a puller and it wont budge. the "toe bolt" comes out fine
#2 |
That Guy
Drives: 2013 asphalt FRS MT
You might need a pickle fork.
#3 |
Drives: 2006 STi
Looks like it might be it, ill check into that . Thanks
#4 |
FT86Club Official Vendor
Drives: Subarus
Hit the knuckle sideways so you're transmitting the force at a 90 degree angle from the ball joint. If you keep hitting it on the stud, you can mushroom the threads.
#5 | |
That Guy
Another easy way to avoid mushrooming the threads is to put the nut on a little proud, and hit the nut. |
#6 |
Drives: 2006 STi
lol tried the hitting the nut and fucked up the threads on the nut. picked up a pickle fork as @Calum suggested and worked like a charm. you sir are a noble gentlemen.
#7 | |
That Guy
Glad you got it worked out. |
#8 | |
Drives: 2003 Subaru Outback
![]() Why cant it always go like this?
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
#9 | |
Drives: Perrin/VORTECH Supercharger TestBRZ
![]() Them is in their tight. Fork worked for me too |
#10 |
Drives: Subarus
With a pickle fork, it's easy to tear the boot. Something to consider if you ever want to reuse or resell. If you hit the knuckle at a 90, after a minute or so, the ball joint will slide off and leaves the toe link in perfect condition.
#11 |
Drives: Toyota 86 GTS
What sort of weight/length sledge would be most suitable?
#12 |
Drives: Subarus
Not very big, 3 lb (1.5 kg) should be okay. It seems futile at first since you don't see it doing anything, but keep at it. Eventually, it'll slide right out.
#13 | |
That Guy
Next time I might try a modified version of HG's idea by using an air hammer instead of a BFH. Should make things easier on the arms and the surronding mounting points. If the snow ever melts and I finally get under my car, I'll report my findings. Sorry it didn't work out for you. |
#14 |
Yes, been there done that too, that was before I decided to go pounding on the bolt!. So word to the next guy, if youre using a fork, careful. You can tell I dont do ball joint type work often, luckily for my cars.
I felt weird pouding on it with the bfh at the 90 degree angle after several blows, but youre saying stay with it, put in the ear plugs and whack-away, huh...will try that next time.Thanks for sure |
| Andriod Headunit with HKS OB-Link? | stevo_12v | Electronics | Audio | NAV | Infotainment | 40 | 04-14-2013 03:31 AM |
| Hancha Rear Toe Link | Hancha Group | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 51 | 04-05-2013 08:18 PM |
| STi Trailing Link Set - Released | Beyer Subaru | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 03-16-2013 12:21 AM |
| Gearbox: Cable Link or Mechanical Link? | Marrk | BRZ First-Gen (2012+) — General Topics | 42 | 07-01-2012 11:45 PM |
