Old 11-03-2012, 06:43 PM   #1
Zaneman
Drives: 2013 BRZ limited
Rear license plate screws
I got my car from the dealer and made sure they didn't drill the front bracket for the license plate. I just installed a Perrin front plate holder and went to install my rear plate and realized I didn't have mounting hardware. Did your car come with a couple screws in the glove box or did you just have to go buy some? Can anyone advise me as to what size I would need?
Zaneman is offline   Reply With Quote
Old 11-03-2012, 06:55 PM   #2
gmookher
auto parts store, or your dealer will have some
gmookher is offline   Reply With Quote
Old 11-03-2012, 07:12 PM   #3
roddy
roddy's Avatar
Drives: '13 Ultramarine
#14 X 3/4" pan (or truss) head stainless steel self tapping (sheet metal) screws. Should be able to get them at any hardware store or Home Depot.
The Following 4 Users Say Thank You to roddy For This Useful Post:
CamryDS (03-22-2014), edgary (04-14-2016), kevaughan (04-25-2022), Zaneman (11-04-2012)
Old 02-28-2014, 12:26 PM   #4
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
Totally resurrecting this thread from the bowels of the dead, but I am not fairing well with Google and trying to convert to metric... I'd like to find a pair of bolts that have a 3mm female hex head (for an allen key), but I am finding my ability to translate numbers from SAE to Metric is making my head hurt... or is that #14 x 3/4" already metricish?
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 02-28-2014, 12:43 PM   #5
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Digging up a thread is better than a repost. Thank you for your effort.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 02-28-2014, 01:24 PM   #6
yberther
yberther's Avatar
Drives: '13 SWP Limited
sae and metric bolts are not interchangeable unless its through a hole, but the threads can not be "converted"
I can't help you with the bolts though. I thought there were plastic plugs to thread into, I don't think you should be screwing into the sheet metal.
yberther is offline   Reply With Quote
Old 02-28-2014, 01:42 PM   #7
Turkish
Serial Cone Killer
Turkish's Avatar
It is plastic, perhaps it can be retrofitted to accept metric.
... his name is...
C'THULHU
Old 02-28-2014, 09:02 PM   #8
roddy
roddy's Avatar
The plastic inserts take a self tapping or sheet metal screw, which has very aggressive threads similar to a wood screw. A regular machine or cap screw (aka a bolt) won't really have the bite needed to grab the plastic. #14 diameter is very close to 1/4" (which itself is very close to 6mm). Keep in mind that the size of a bolt is the diameter of the threaded part, not the size of the head. Back when I was selling fasteners, I couldn't count the number of times someone came to the counter asking for a 9/16" bolt, then dropping a 3/8" bolt on the counter with a 9/16" head on it.
Old 03-22-2014, 10:30 PM   #9
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
You can use 1/4 x 3/4 security screws. These are torx screws with a hole in it. 3.00 at lowes.
H#884690 a52.
I lost both of mine today while washing my car... so I had to replace it.
Sent from my SM-N900P
Excuse the typos
CamryDS is offline   Reply With Quote
Rear License Plate Scratch DBacon1052 Issues | Warranty | Recalls / TSB 11 09-20-2012 04:06 AM
[For Sale] Rho-plate Tow Hook Mounted License Plate rack pizzahead20 Canada Classifieds 0 08-23-2012 12:06 AM
Rear License Plate Frame ashtray Cosmetic Modification (Interior/Exterior/Lighting) 19 07-23-2012 01:47 AM
No License Plate? tjdiz92 NY / NJ / CT / PA 19 06-25-2012 02:14 PM
rear license plate frame meekhotglass Cosmetic Modification (Interior/Exterior/Lighting) 1 06-20-2012 10:08 PM
