Old 09-17-2012, 10:18 PM   #1
DBacon1052
DBacon1052's Avatar
Drives: Argento FR-S
Rear License Plate Scratch
Saw this happened to someone else so I checked to see if mine was scratching the car. Sure enough, there is a big long scratch where the license plate rests. What should I do?
DBacon1052 is offline   Reply With Quote
Old 09-17-2012, 10:22 PM   #2
mashal
DADA
mashal's Avatar
Drives: 2013
Foam tape on the back side , that's what I did
I-Tapatalk
mashal is offline   Reply With Quote
Old 09-18-2012, 08:21 AM   #3
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
I used some double sided tape that comes with the command series of hooks. They are made to remove easy without any damage. This way the plate is not touching the paint and it does not flop around.
jadewbj is offline   Reply With Quote
Old 09-18-2012, 01:23 PM   #4
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
My license plate "frame" was touching the paint, so I took it off. My license plate itself does not touch the paint.
Sigh-on-Rice is offline   Reply With Quote
Old 09-19-2012, 09:02 AM   #5
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
I covered the back of my plate with foam weatherstripping.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
The Following User Says Thank You to deucethemoose For This Useful Post:
ftc~brz (09-19-2012)
Old 09-19-2012, 10:55 PM   #6
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
I put dynamat on the back of my plate.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 09-20-2012, 12:05 AM   #7
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
yeah my license plate scratched the back of my car too
i sanded the sharp edges of the plate frame and i also taped it up to smoothen out the edges as temporary solution, im planning to get some foam tape to put on my plates
Old 09-20-2012, 01:09 AM   #8
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
foam tape works well
86_ZN6 is offline   Reply With Quote
Old 09-20-2012, 01:30 AM   #9
NMMI89
Master of Chaos
NMMI89's Avatar
Drives: 2013 Asphalt Scion FR-S
Thanks for the tips y'all. Quick question...Any y'all have a problem with the screws for the rear license plate holder? My screws don't seem to screw all the way flush. I don't have my plates yet as my FR-S is 10 days old. Could that be a reason?
NMMI89 is offline   Reply With Quote
Old 09-20-2012, 01:56 AM   #10
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
You should adhere the foam to the car. If you attach it to the plate, dirt can get caught between the foam and your car, and still scratch it.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 09-20-2012, 02:37 AM   #11
gmookher
use rubber in an X or O shape with slits for drainage for water that gets behind plate, instead of foam, it wont trap dirt = trapping moisture= rust years later
gmookher is offline   Reply With Quote
The Following User Says Thank You to gmookher For This Useful Post:
86_ZN6 (09-20-2012)
Old 09-20-2012, 04:06 AM   #12
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Put electrical tape on the bottom and sides of your license plate. Used this technique for years
SMOKETREES is offline   Reply With Quote
WHere can I get this license plate? Silverback Scion FR-S / Toyota 86 GT86 General Forum 0 09-06-2012 07:09 PM
Scratch + dent on rear quarter panel - fix or no? rawbz Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 10 08-26-2012 11:50 AM
[For Sale] Rho-plate Tow Hook Mounted License Plate rack pizzahead20 Canada Classifieds 0 08-23-2012 12:06 AM
Rear License Plate Frame ashtray Cosmetic Modification (Interior/Exterior/Lighting) 19 07-23-2012 01:47 AM
rear license plate frame meekhotglass Cosmetic Modification (Interior/Exterior/Lighting) 1 06-20-2012 10:08 PM
