Old 03-15-2026, 12:42 PM   #1
Don Ivey
Drives: '13 FR-S
Seeping Oil Around Drain Plug
I changed my oil on 2013 FR-S, and tightened new crush washer to 30ft-lbs torque, and it is dripping a small puddle after driving. I did buy crush washers at a local auto parts store, and they look ok. Could I use some of that teflon tape around the drain plug, with a new crush washer, to stop the leak? Or is there a better solution. TIA,
Don Ivey
'13 FR-S (Hot Lava)
Don Ivey is offline   Reply With Quote
Old 03-15-2026, 01:15 PM   #2
Ohio Enthusiast
Drives: 2018 BRZ
Did you make sure to remove the old crush washer? Sometimes it gets stuck to the pan or the bolt, and doubling them might cause a leak.
Teflon tape won't help - the seal is not at the threads like a water pipe connection, but between the head of the bolt and the pan via the crush washer (with the crush washer acting line an O-ring).
I use Fumoto valves on all my cars. They come with a rubber gasket and tightening torque is lower, might be a good time to replace the bolt with a valve.
Ohio Enthusiast is offline   Reply With Quote
The Following 4 Users Say Thank You to Ohio Enthusiast For This Useful Post:
bcj (03-17-2026), Spuds (03-25-2026), Wally86 (03-25-2026), whataboutbob (03-15-2026)
Old 03-15-2026, 03:18 PM   #3
Don Ivey
Drives: '13 FR-S
Thanks, that was exactly the problem. Don't know if I left an old one on there, or if someone else did, but the extra one deformed, causing the leak. I'll have to be more careful next time
Don Ivey
'13 FR-S (Hot Lava)
The Following 5 Users Say Thank You to Don Ivey For This Useful Post:
bcj (03-17-2026), Ohio Enthusiast (03-15-2026), T-Steve (03-15-2026), Wally86 (03-25-2026), whataboutbob (03-15-2026)
Old 03-25-2026, 08:21 AM   #4
slim blanco
slim blanco's Avatar
Drives: 2017 86
glad you solved your issue. just wanted to mention that i've successfully used teflon tape on leaky oil pan drain bolts in the past, so it could be used if you need a little extra seal. i kept it wrapped mostly near the head of the bolt so the tape didn't protrude into the pan too much.
slim blanco is offline   Reply With Quote
Old 03-25-2026, 09:32 AM   #5
Don Ivey
Drives: '13 FR-S
That's probably a safe way to use the tape, but the single fresh crush washer seems to be holding for now. Cheers!
Don Ivey
'13 FR-S (Hot Lava)
why is the oil drain plug not designed at the lowest point of the oil pan? qiumaoyuan Engine, Exhaust, Transmission 1 08-19-2024 04:59 AM
Beware || oil drain plug washer (when changing your oil) mav1178 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 11-14-2021 06:07 PM
Oil Cooler Lines Constantly Seeping. Gloonge Engine, Exhaust, Transmission 23 12-10-2020 07:27 PM
Anyone else just living with their timing cover seeping? tracerit Issues | Warranty | Recalls / TSB 10 05-19-2018 06:58 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 07:36 PM
