Old 08-18-2024, 10:08 PM   #1
qiumaoyuan
qiumaoyuan's Avatar
Drives: 2017 BRZ MT, 2009 Civic sedan AT
Question why is the oil drain plug not designed at the lowest point of the oil pan?
resulting in the inability to completely drain the old oil during an oil change
qiumaoyuan is offline   Reply With Quote
Old 08-19-2024, 04:59 AM   #2
Trollhart
Trollhart's Avatar
Drives: 2013 Subaru BRZ Sport
Because if you scrape, you want your drain plug to not be ripped off.
If you angle the car properly, you will be able to drain most of the old oil.
In case you absolutely want to get the last drop of the old oil out, you can use a syringe, but normalls this is not necessary.
Trollhart is offline   Reply With Quote
The Following User Says Thank You to Trollhart For This Useful Post:
cmiovino (08-19-2024)
Need help extracting drain plug... SamtheKorean Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 33 01-25-2020 05:18 PM
Quick Drain Plug dholloway543 Engine, Exhaust, Transmission 29 11-14-2019 01:08 PM
Why isn't there a 2nd drain plug on the bottom of AT oil pan? FT86.ca Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 03-04-2017 08:40 PM
Drain plug leaking...what to do... OUGrad05 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 03-28-2016 02:01 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 07:36 PM
