Old 05-18-2018, 12:42 PM   #1
tracerit
Drives: '13 SSM BRZ Limited 6MT
Anyone else just living with their timing cover seeping?
I've had it resealed twice and it's been ok for the last year until I changed my oil the other day and noticed it's slowly seeping. It's not bad but sucks as my warranty ended 2 months ago.
I'm considering just driving the car as it is since it's not leaking horribly, I'll just wipe it clean every 5k miles oil change.
But I'm curious what it would cost to get it resealed (I'd probably request a new timing cover as well) out of pocket?
tracerit is offline   Reply With Quote
Old 05-18-2018, 01:38 PM   #2
majixmatrix
BRZ Wannabee
majixmatrix's Avatar
Drives: 2013 Limited BRZ
I had a local shop identify this for mine too just a little while ago :/ mine is just a slow seep and thankfully is on the driver's side so it won't drip onto the hot header. I asked the guy for cash how much he'd do it for and labor alone he said probably at least $300 as he has to lift the engine, but through a dealershit it will cost a pretty penny. Unless it's bad I would suggest just letting it be and wipe it down when you can, being sure to keep an eye on it every couple hundred miles.
Wish you the best!
majixmatrix is offline   Reply With Quote
Old 05-18-2018, 01:56 PM   #3
humfrz
Bubba says to just tape a sponge over the leak and change it every oil change .....
humfrz
ermax (05-18-2018)
Old 05-18-2018, 02:28 PM   #4
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Ask the dealership if they will cover it under warranty even though you're over. They may even split the cost with you.
Old 05-18-2018, 03:00 PM   #5
ermax
ermax's Avatar
Well luckily these cars eat rod bearings so you can just reseal the cover while rebuilding the engine. Hahaha.
The Following User Says Thank You to ermax For This Useful Post:
gravitylover (05-18-2018)
Old 05-18-2018, 04:08 PM   #6
strat61caster
strat61caster's Avatar
I think I'll live with it until I hit about 100k, I'll do a coolant flush and then reseal while I can do the work without the radiator installed.
ineedyourdiddly
Old 05-18-2018, 04:23 PM   #7
Just don't change the oil for a year or so and eventually it will thicken up and plug the leak.
finch1750 (05-18-2018), gravitylover (05-18-2018), Hawk77FT (09-25-2019), humfrz (05-18-2018)
Old 05-18-2018, 06:57 PM   #8
humfrz
Reminds me of the opposite ..... back-in-the-day. As long as you used non-detergent oil ..... your engine didn't leak ..... but then put that new detergent oil in it ...... and it leaked.......
humfrz
Tcoat (05-18-2018)
Old 05-18-2018, 09:28 PM   #9
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Yup. Mine has been like that for a long while. Not bad but it builds up over time so I know its happening
Old 05-19-2018, 06:50 PM   #10
Decep
Drives: 2013 FR-S Series 10
humfrz
Wonder if using a heavier weight oil would help as well.
Old 05-19-2018, 06:58 PM   #11
humfrz
Well, back in the day, that would work. For the crank case, we would mix 30W with gear oil. For the transmission, we would use gear oil. For the differential, we would pump the differential full of axle grease and top it off with gear oil.
However, for these cars, I wouldn't recommend that ......
humfrz
Timing cover leak sid94 DIY (Do-It-Yourself) Guides 4 04-03-2018 03:06 PM
Timing cover leak sid94 DIY (Do-It-Yourself) Guides 5 12-16-2017 03:19 PM
Timing Cover Oil Leak Keenercarguy Issues | Warranty | Recalls / TSB 66 05-30-2016 11:59 PM
Oil Leak from either Timing Cover or Valve Cover BRZY Issues | Warranty | Recalls / TSB 5 04-06-2015 08:31 AM
oil leak at timing cover choi0706 Issues | Warranty | Recalls / TSB 8 09-10-2014 06:25 PM
