Old 06-17-2023, 12:06 AM   #1
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Header Stud Installation Questions
I need to replace one of the studs in the head that the header is fastened to. Old one came out seized to the nut, and I think the threads in the head are fine. Hoping to get the forum's wisdom on this.
Question 1: antiseize?
Question 2: torque?
Question 3: Procedure is remove header, double up nuts on the stud going in, torque it down using nuts, remove nuts, install header right?
Edit: make that 2 studs...
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread"
Old 06-17-2023, 07:16 AM   #2
Ashikabi
Ashikabi's Avatar
I don't have answers for you but surely there are instructions online for studs. Although possibly for a different car. Should be pretty standard industry wide
Sent from my KB2007 using Tapatalk
Old 06-17-2023, 12:33 PM   #3
Spuds
The Dictater
Spuds's Avatar
Ok, here's what I did
1. No
2. Yes... 13 ftlb or 156 inlb
3. Yes
For reference, the issue is I got locking nuts and though they went on ok, coming off some of them were ripping bits of thread off and getting stuck. Avoid oblong style steel lock nuts for headers. I'm just using new OEM nuts now.
Old 06-17-2023, 12:50 PM   #4
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I've reused (GASP!) my oem nuts 3 times. Never any problem. IMHO locking nuts are not needed.
Old 06-17-2023, 09:43 PM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Same. Reused oem non-locking header nuts 4 times.
I put a small dot of antiseize, though I don't live in a rustprone area. Just a precautionary measure based on how often the overpipe hardware tends to snap.
As for stud removal/installation, double nut method. I torque studs on, but the spec is quite low (for example, the transmission stud torque is 7 ft-lb). So the concern is more about avoiding stripping the aluminum block over the stud falling out
EndlessAzure is offline   Reply With Quote
broke a stud today and have a few questions about lugs and studs Breadman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 11-29-2018 12:34 PM
H&R DRS Spacer (3025560) Stud installation question Dihudaxia Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 10-19-2015 09:16 PM
Overpipe Installation Questions hattrickey Engine, Exhaust, Transmission 21 09-23-2015 01:27 PM
Broken stud on stock header BAMF86 Engine, Exhaust, Transmission 1 06-06-2014 04:27 PM
flush with stock wheels. with Stud installation. adamturbo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 12-10-2012 04:30 AM
