Old 06-15-2012, 08:37 PM   #1
adamturbo
Drives: mitsubishi evo 9
flush with stock wheels. with Stud installation.
using H&R trax wheels spacers part #3025560 . these are 15mm and include longer studs. this setup will push your wheels out nicely.
front studs are easy to install but on the back you can only get the longer stud in at a certain position.
here is the hub position on the back to get the studs in.
to get them in you will need a tube or 2 big nuts that slide over the stud. use a lug nut and tighten the stud in. use a big socket on the center nut to stup the hub rotating.
and finished
easy 30 min. spacers and studs are around 130 per pair.
adamturbo is offline   Reply With Quote
Old 06-15-2012, 08:41 PM   #2
vividracing
vividracing's Avatar
Thanks for posting! I usually use a stack of washers instead of the nuts. Same result, but washers are probably easier to find.
vividracing is offline   Reply With Quote
Old 06-15-2012, 09:07 PM   #3
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
let me know how it holds up. any issues down the road, etc
dori. is offline   Reply With Quote
Old 06-15-2012, 09:42 PM   #4
Calum
That Guy
Drives: 2013 asphalt FRS MT
Pics from farther away please, I'd like to see the overall look.
Old 07-21-2012, 01:18 AM   #5
FRS8SIX
Drives: 2013 hot lava FR-S
sorry to bring this back up haha, do you have any side shots or more pics?
FRS8SIX is offline   Reply With Quote
Old 07-21-2012, 01:56 AM   #6
atledreier
Drives: GT86 DGM
Putting spacers on must play havoc with your suspension geometry, no?
atledreier is offline   Reply With Quote
Old 07-21-2012, 02:09 AM   #7
StevenEngage
StevenEngage's Avatar
Drives: 1995 Nissan Sentra
Are the spacers hub-centric?
StevenEngage is offline   Reply With Quote
Old 07-21-2012, 02:17 AM   #8
StevenEngage
Wait...wth? I thought all fr-s' were disc in back? confused. lol
Old 07-21-2012, 02:53 AM   #9
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
It is Disc with a separate drum brake inside the disc for the E-Brake.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 07-21-2012, 02:57 AM   #10
StevenEngage
ohh I see, thanks for clearing that up
Old 07-21-2012, 11:04 AM   #11
ZDan
ZDan's Avatar
Drives: '23 BRZ
I just use stacks of washers instead of wheel spacers. Same effect, much cheaper/easier
[j/k! Don't do this. Really bad things, 4 realzies...]
Old 07-21-2012, 11:59 AM   #12
Calum
That Guy
NO.
Washers aren't machined to nearly the tolerances required to keep the wheel straight, not to mention you wont have sufficient threads for the nut to hold on to. Using a stack of washers is a great way to watch as a wheel races your car and wins.
Old 07-21-2012, 02:17 PM   #13
ZDan
ZDan's Avatar
Drives: '23 BRZ
Hence the above...
Actually, even if washer stacks were identical height to a c-hair, and lug studs were long enough, they would still be a very very VERY bad idea for other reasons as well. The stack would allow the wheel to move radially and the lug studs would see a lot of bending load.
So, to be sure, I'll add a j/k note above^^^
Old 07-21-2012, 03:09 PM   #14
vividracing
H&R spacers for the most part are.
Originally Posted by Calum View Post
NO.
Hence the above...
Matt who posted for me above was talking about seating the new wheel stud. Not using washers to space the wheels. That would be really bad.
225/45/17 on stock 7" wheels? ubersoph Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 04-09-2014 04:59 PM
Which 18" wheels will weigh the same or less than the stock wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 05-16-2013 03:07 PM
SiriusXM installation to stock Scion FR-S unit tonystewart Electronics | Audio | NAV | Infotainment 9 07-17-2012 08:10 PM
Aftermarket wheels on stock BRZ/86s yajin BRZ Photos, Videos, Wallpapers, Gallery Forum 2 05-01-2012 02:52 AM
Why can't the BRZ GT300 or factory BRZ wheels have flush fitment? switchlanez BRZ First-Gen (2012+) — General Topics 43 03-19-2012 12:50 PM
