Old 06-06-2014, 03:53 PM   #1
BAMF86
much slow
BAMF86's Avatar
Drives: 13 Raven FRS, 05 Rio Yellow S2000
Broken stud on stock header
Last night while installing my motiv overpipe to my stock header, one of the studs snapped in half when removing the one of the two nuts where the overpipe and header meet.
I used WD40 on them before trying to remove them but I guess they seized up pretty badly
So now I have a pretty bad exhaust leak since only one nut keeps them together. My question is, would there be any possible way to replace the stud?
I want to hold out on purchasing a brand new header but there might be no other option.
I can also try seeing if the dealership will cover it under warranty, but I have a full headerback so they might give me shit for it.
BAMF86 is offline   Reply With Quote
Old 06-06-2014, 04:27 PM   #2
FR-S Matt
I'd check the engine/exhaust section as you will catch people selling a stock header. Might be worth it, but at this point, I'd just get an aftermarket one.
You want a true cheap fix? Have a shop plasma cut holes into your stock header and create an aftermarket-like hole. Much better option then just put a regular nut/bolt combo on it and call it done. I had a seized nut on my stock header and had the studs cut off then holes blown through. Worked out real well.
Sheared/Siezed ARP stud (after having 3 stock studs strip) Kostamojen Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 75 01-30-2016 09:44 PM
Need Advice: Broken strut mount stud... cobrabyte Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 12-22-2014 04:37 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Broken Stut mount Stud. Anyone Did This Before? Figo Issues | Warranty | Recalls / TSB 3 07-19-2013 10:29 AM
flush with stock wheels. with Stud installation. adamturbo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 12-10-2012 04:30 AM
