Old 12-04-2013, 08:47 PM   #1
hattrickey
Drives: Scion FR-S
Overpipe Installation Questions
I currently have the Perrin catback and catted front pipe. I'm looking to add the overpipe and I have a few questions for the people who have done this mod.
When installing, I know some people remove the heat shields in order to not have to jack the engine up. In the long run, will this hurt the car? Do you replace the heat shields after you install the new pipe, or just leave them out? Any specific reason for keeping them off or not?
For the people who jacked the engine up, the heat shields stay in correct? Any clearance issues?
Thanks for the help
hattrickey is offline   Reply With Quote
Old 12-04-2013, 09:16 PM   #2
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
The heat shields are attached to the pipe they won't fit the Perrin pipe. I personally haven't had or heard of any issues with the perrin pipe without the heat shield, but I also haven really pushed mine since I installed it. If you're concerned about heat you could wrap the overpipe before installing it.
As for installing save yourself some hassle and just unbolt the right rear engine mount and jack the engine up. I tried removing the heat shield and getting it out that way but it was just a wast of time jacking it up was quick and easy.
Old 12-04-2013, 09:24 PM   #3
pche
Guy on internet
Drives: Slowly
Heat shields are on the OEM over pipe, aftermarket over pipes don't have heat shields.
Btw, jacking up the motor is a hell of a lot easier than taking the heat shields off, IMHO.
pche is offline   Reply With Quote
Old 12-04-2013, 09:27 PM   #4
DR 86
DR 86's Avatar
Jack up engine, no heat shield on aftermarket. No issues either after track days and hard daily driving with full engine-back exhaust.
Perrin CAI|Perrin MCB|P&L header|Motiv OP/FP|MXP catback|Tein Type Flex coilovers|Eibach F/R sway bars|GS front strut brace|Street:PM HC+800/Track:Carbotech XP10|StopTech slotted rotors/SS lines|SBC RPF1s|Street:FK453/Winter:Pirelli SottoZero3/Track:Toyo R888s|Leg Sport rear spoiler|EcuTek Tuned|OEM oil cooler|4th/F1 brake lights
DR 86 is offline   Reply With Quote
Old 12-04-2013, 09:40 PM   #5
cnk
Drives: '13 DGM BRZ Limited
Only took 5m to take the heat shields off and wiggle the pipe out the back. Don't know why some folks complain about taking them off as they are so easy to remove.
Sent from my SAMSUNG-SM-N900A using Tapatalk
cnk is offline   Reply With Quote
Old 12-04-2013, 11:33 PM   #6
hattrickey
Drives: Scion FR-S
Awesome, thanks for the information guys. Definitely helps put me at ease about the heat shields.
Old 12-05-2013, 03:34 PM   #7
Rev Works
Rev Works's Avatar
Drives: 2013 STi
Every time we install an overpipe we just jack up the motor a little to make the clearance. Much easier than fussing with the heat shields.
-Matt
Rev Works is offline   Reply With Quote
Old 12-05-2013, 05:43 PM   #8
AL008
Drives: Celica 04
Where are the best jacking points on the motor without denting anything?
AL008 is offline   Reply With Quote
Old 12-05-2013, 07:17 PM   #9
cnk
Block of wood under the oil pan to spread the load so you don't dent it.
Old 12-05-2013, 07:19 PM   #10
DJCarbine
Thupercharged
DJCarbine's Avatar
Another vote for heat shields.
If it takes longer than 5 minutes or the bolts are rusted, jack the engine up
2013 FRS
Vortech V3 11psi
Old 12-06-2013, 09:20 AM   #11
hattrickey
Drives: Scion FR-S
-Matt
So by not fussing with the heat shields, you leave them in? Or you take them out once you jack up the motor and remove the factory overpipe?
Old 12-06-2013, 11:31 AM   #12
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
The heat shields are wrapped around the factory overpipe. They come out attached to it if you jack up the engine and remove it that way.
I'm with many others and jacked the engine up to remove mine. Easy Peasy.
FRSFirestorm is offline   Reply With Quote
Old 12-06-2013, 11:58 AM   #13
PERRIN_Mladen
PERRIN_Mladen's Avatar
Drives: '11 535i
If you go HERE, you will be able to read our instructions prior to actually purchasing the part.
Hopefully it helps clear it up for you a bit!
PERRIN_Mladen is offline   Reply With Quote
Old 12-08-2013, 04:15 PM   #14
hattrickey
Drives: Scion FR-S
Awesome. Thanks for all of the info!
Headers & downpipe/overpipe installation Sonolin Engine, Exhaust, Transmission 23 09-23-2015 01:58 PM
OEM Overpipe Philly758 Want-To-Buy Requests 2 09-04-2013 08:45 AM
Motiv Concepts Overpipe + HFC, Overpipe + Test Pipe Specials! MotivConcepts Engine, Exhaust, Bolt-Ons 96 07-19-2013 02:03 AM
WTB overpipe jamesm Engine, Exhaust, Bolt-Ons 0 06-30-2013 08:01 PM
Greddy EVO 3 + front and overpipe questions jonbonazza Engine, Exhaust, Transmission 5 06-02-2013 10:00 AM
