Old 10-19-2015, 08:00 AM   #1
Dihudaxia
Drives: 86
H&R DRS Spacer (3025560) Stud installation question
I am purchasing a pair of H&R 15mm Spacers, 3025560, from the instructions, i need to install the H&R wheel studs as this is a slip on set.
H&R has informed me that the H&R supplied stud is a 12x1.25 stud with a knurl diameter of 14.45mm, but to my best knowledge, our stock studs have a knurl diameter of 14.38mm (2011 Subaru WRX spec) which is ever so slightly thinner.
I have read reviews of someone here installing this set onto his BRZ/FRS, and it seems ok, but will this slightly wider H&R stud really fit onto our hub perfectly or am i overreacting?
Thanks!
Dihudaxia is offline   Reply With Quote
Old 10-19-2015, 02:49 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
If it's 14.xxmm it will be fine.
There's only 12.65mm and 14.3mm knurls (approx.)
Old 10-19-2015, 09:16 PM   #3
Dihudaxia
Drives: 86
Thanks mav1178!
Much appreciated.
Spacer question for OEM wheels Mrqb22 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-26-2016 05:25 PM
AEM 320 Pump installation question Gixxer86 Engine, Exhaust, Transmission 0 10-11-2015 12:35 AM
Spacer question Midnight Dream 86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 01-26-2014 09:37 PM
Wheel spacer question, please help AceNiNe Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 11-23-2013 03:52 AM
flush with stock wheels. with Stud installation. adamturbo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 12-10-2012 04:30 AM
