Old 04-22-2022, 07:44 PM   #1
AGriggs
86 Fan
Drives: 2019 86 GT
Question ACE Header install issue
Hi all, I have a 2019 86. I've been working to getting ACE A350 headers installed, but ran into a problem. I got the stock exhaust manifold off, but as I went to install the ACE overpipe, I realized the headers don't come with the studs to mount the overpipe to the front pipe. Am I supposed to remove the studs from the stock overpipe to use with the new one? I don't have a ton of tools at my disposal and getting the old studs out hasn't worked yet. I do have them soaked in PB Blaster right now, so I'll give them another try tomorrow.
At this point, I'm thinking that just buying new studs is the way to go. Can anyone point me to an exhaust parts diagram with the studs showing the part number? Did anyone have a similar experience? Any advice?
Thanks
AGriggs is offline   Reply With Quote
Old 04-23-2022, 01:41 AM   #2
e1_griego
e1_griego's Avatar
Drives: Many
Should just have bolts that thread into the overpipe flange. I they're m8x1.25 thread pitch.
e1_griego is offline   Reply With Quote
Old 04-25-2022, 08:39 PM   #3
AGriggs
86 Fan
Drives: 2019 86 GT
I had no bolts that went to the overpipe flange, only studs in the stock overpipe that were not wanting to unscrew for me. I ended up going to a dealership to get fresh studs and those worked great. I got my header installed and I'm now working on getting the tune done.
ace, exhaust, header, help me, studs
Coilover install issue CAPSLOCK Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 05-27-2019 09:27 PM
OEM BRZ fog light install issue csol Cosmetic Modification (Interior/Exterior/Lighting) 5 12-16-2018 10:00 PM
weird issue after BPB & OFT install DAN_BRZ Engine, Exhaust, Transmission 10 06-10-2014 09:53 PM
Koni Install Issue WolfSongX Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 07-22-2013 09:17 PM
Pulley install issue Boxer-86 Engine, Exhaust, Transmission 9 10-21-2012 07:37 PM
