Old 07-13-2013, 05:58 PM   #1
WolfSongX
WolfSongX's Avatar
Drives: 2013 Subaru BRZ Limited SWP
Koni Install Issue
Hopefully I have the right part number, but I'm doing a rear strut install with Koni struts and RCE yellows, but the shaft of the Koni is thicker than the OEM shaft. Unfortunately the hole in my rear strut top is too narrow for the threaded portion of the Koni shaft.
Anyone run into this before?
If I need to drill out the hole in the top mount, what size drill bit.
Part # on box is 8041 1416SPORT
I've bought another set of suspension, so the top mounts I'm using are from a FR-S and my car is still together, so I'm not stuck, but I'm getting a bit frustrated.
Derek
2013 BRZ Limited SWP
Professional driver in search of closed course..
WolfSongX is offline   Reply With Quote
Old 07-13-2013, 06:36 PM   #2
FastLane1000
FastLane1000's Avatar
Drives: White FR-S, 6M
Yeah, you got to drill it. I'm not sure of the size just match the bit up with Koni threads. I'm not sure on the part numbers but I remember having to drill.
FastLane1000 is offline   Reply With Quote
Old 07-13-2013, 06:44 PM   #3
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
just checked for you. same part number as mine. We didnt have to drill anything. Also on konis with RCE yellow springs. Ill go take a pic
Scratch that Im a big fat liar. I just got confirmation that the top hats were in fact drilled. I was away taking the fronts apart. Sorry for any confusion. I believe this is described in the instructions no?
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 07-13-2013, 07:21 PM   #4
WolfSongX
WolfSongX's Avatar
Thanks guys, I didn't see anything in the instructions, but the Koni instructions can be a little confusing. I'll look at them again just in case I missed it. I'll just try stepping up one drill bit size until it clears.
Also on the rears, the RCE bumpstops don't fit over the spacer that is welded below the threads either, so I wound up using the OEM bumpstop cut down to the same size. I also reused the OEM gaiter as well since the OEM bumpstop wasn't wide enough to hold the RCE gaiter in position.
The fronts went together easily in comparison...
I've been taking a lot of pics and notes to post a DIY on the conversion...
Any more feedback/suggestions are very welcome.
Derek
Last edited by WolfSongX; 07-13-2013 at 07:27 PM. Reason: changing response when feldy confirmed drilling was needed
Old 07-13-2013, 08:32 PM   #5
WolfSongX
WolfSongX's Avatar
Well I had a 7/16ths and a 1/2" bit... and 7/16ths is not quite enough and the 1/2 is maybe a bit too much. I hate not having a set of metric drill bits.
I'm waiting for the paint to dry and will try again a bit later or tomorrow depending on how I feel.
Derek
Old 07-13-2013, 10:11 PM   #6
SVThis
SVThis's Avatar
Drives: Scion FRS
Use a 12mm drill bit per instructions
We're not happy till you're not happy
2013 Scion FRS Whiteout 6MT
SCCA RTR/Konis/RPF1's/Dunlop Z2's/Strano front bar/CG Lock/Crash camber bolts/JPM shift boot and Instrument panel cover.
SVThis is offline   Reply With Quote
Old 07-14-2013, 07:06 AM   #7
WolfSongX
WolfSongX's Avatar
I must be missing a sheet then, there was no reference to drilling in the instructions I received with the struts from Koni.
Derek
Old 07-16-2013, 06:08 PM   #8
JRP
JRP's Avatar
Drives: 2013 Perl White FR-S
The 12mm is the size hole you need to drill in the bottom of the strut body for the bolt that holds the damper in place. I just took a round file and carefully opened the hole until the top of the damper fit.
Jim
JRP is offline   Reply With Quote
Old 07-16-2013, 06:09 PM   #9
OrbitalEllipses
Drives: Attitude
Girly man arms? It don't look like it fit, but you can muscle the bumpstop over it (I did). Watch out though, don't want to cut yourself on that slag-welded POS.
I used a 1/2" drill bit for the rear top hats...fits fine. Not many people on this side of the pond have metric drill bit sizes or tradesman's assortment of bits.
Old 07-22-2013, 09:51 AM   #10
rikdrt1
Hypnotic FRS Member
rikdrt1's Avatar
Drives: FR-S [Raven]
that scares me already... don't like drilling something that will affect OEM if I ever go back..
rikdrt1 is offline   Reply With Quote
Old 07-22-2013, 10:12 AM   #11
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
New top mounts should be relatively cheap... significantly cheaper than buying completely new front struts since you just gutted those for the front inserts.
In all, its a 2mm ID delta, you can always use a spacer/washer if you are that worried about it not being centered or if you are worried about the interfacing area being insufficient for the load when you go back. The rear damper doesn't play into the alignment of the rear wheel, so that tiny fraction of a degree of change you would get from +/- 1mm in each direction will be insignificant.
I'm not sure why exactly you would ever want to go back to OE dampers... Koni yellows shouldn't be considered a performance modification in terms of a warranty, if that is what you are concerned about. They are basically an OE replacement damper, using very typical OE replacement damper installation methods.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 07-22-2013, 04:49 PM   #12
WolfSongX
WolfSongX's Avatar
I took a ton of pics with doing this conversion and finally got them on the car. I didn't document the install/removal because that's been done a few times already. Hopefully my ancient computer will behave and work (I use a tablet from home now and I'm not allowed to use my work computer for image editing/uploading.) so I can get the images processed and uploaded.
I still need to get the alignment done, so I haven't had a chance to really test things out or play with the adjustable settings on the strut. I'm running the struts on full soft at the moment, but the most noticeable thing is how smooth the weight transitions are with this car now... and stock it wasn't a slouch, so that's saying a lot.
I wouldn't say that you give up a lot of comfort, but the car feels noticeably lower now and very solidly planted. Win-Win in my book.
Derek
Old 07-22-2013, 08:41 PM   #13
OrbitalEllipses
Drives: Attitude
Heh, turn it up to 2 turns from soft and see how you like that. At full soft they DO ride better than the OEM setup, though.
Old 07-22-2013, 09:17 PM   #14
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Bouncy as bananas though.
raul is offline   Reply With Quote
KONI SHOCK VALUE SALE limited time only @ Circuit Motorsports! Lower prices all Koni Circuit Motorsports Brakes, Suspension, Chassis 115 08-30-2013 10:29 AM
Need help fast - suspension issue during spring install finch1750 Scion FR-S / Toyota 86 GT86 General Forum 5 07-08-2013 03:30 PM
Koni inserts or wait for full Koni replacements Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-18-2013 05:48 PM
KONI!! Are here! Turn in Concepts Brakes, Suspension, Chassis 14 04-01-2013 06:38 AM
Pulley install issue Boxer-86 Engine, Exhaust, Transmission 9 10-21-2012 07:37 PM
