Old 06-09-2014, 01:21 PM   #1
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
weird issue after BPB & OFT install
I am experiencing a few issues since ive installed my BPB w/OFT tune.
When the car is cold, it will randomly stall when i come to a light or stop sign, this has happened 4 times now since installing 3 weeks ago. normally happens if im leaving in a rush and dont let the the car warm up. i normally let the the car warm to reg idle and then go.
Second issue i am having appears to be with the tune itself. i seem to get a hicup/misfire or some weird lag around 3-3100 rpm range, hard to explain, but u can feel it. car seems to act strangely around that rpm under but only during light throttle. if im on the gas a bit more i dont notice it at all. anyone else experience this.
Thanks.
DAN_BRZ is offline   Reply With Quote
Old 06-09-2014, 09:31 PM   #2
Basket Case
Drives: 2013 Raven fr-s
Have you tried pulling a battery terminal and resetting the ecu?
Basket Case is offline   Reply With Quote
Old 06-09-2014, 09:37 PM   #3
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Shouldn't be necessary after flashing a new tune.
Old 06-09-2014, 09:39 PM   #4
Basket Case
It shouldn't be, but it's worth a try.
Old 06-09-2014, 09:42 PM   #5
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
If the problem occurs on your stock tune, you know it's a physical problem. If it goes away then it may be a tune issue.
Old 06-09-2014, 10:04 PM   #6
jflogerzi
jflogerzi's Avatar
Thanks.
Don't you need a tune for those to be even effective? Most people lost power till properly tuned. Did shiv send you a tune to support these mods?
Old 06-09-2014, 10:51 PM   #7
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Yeah, I would try the stock tune and eliminate that possible cause. Also be sure your vacuum hose is zip tied down at the back of the intake. The hose is too short once the BPB is/are installed and needs to be checked. An air leak will cause idle problems. This happened to me when I first installed my BPB. Zip tied both ends and no issues since.
JimmyMac is offline   Reply With Quote
Old 06-09-2014, 10:52 PM   #8
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
I would suggest just directly calling Vishnu.
calmtigers is offline   Reply With Quote
Old 06-09-2014, 11:29 PM   #9
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
This would be my suggestion as well. When we first installed BPB on our shop car, we ran into this issue. If you have a leak there, you will have stalling issues. Definitely worth checking out. It's unlikely to be a tune issue since the BPB maps are 99% the same as the standard OTS maps. Only difference is some minor tweaks to fuel/timing/vvt at high RPM. Definitely wouldn't introduce any idle issues.
Cheers,
shiv
Old 06-10-2014, 10:09 AM   #10
DAN_BRZ
DAN_BRZ's Avatar
I did zip tie the top vac hose and i know that its good and tight but im a dumb ass and didnt think about zipping down the bottom part of the vac line. i will do that tonight. its not really an idle issue, the does idle fine 99% if the time. just random stalls when not fully warm coming to a stop... but ill zip my lower hose tonight.
Old 06-10-2014, 09:53 PM   #11
Turdinator
Señor Member
Turdinator's Avatar
A vacuum leak would be my first guess also.
1974 TA22 Celica
2013 86 GT
MTEC shifter spring install issue jamesm Engine, Exhaust, Transmission 36 12-06-2015 09:36 AM
weird issue at high speeds after OFT tune dejxx Software Tuning 24 08-10-2014 09:49 PM
Koni Install Issue WolfSongX Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 07-22-2013 09:17 PM
Weird Sound After Coilover Install (when moving steering wheel left and right) taimysho0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 07-20-2013 01:18 AM
Pulley install issue Boxer-86 Engine, Exhaust, Transmission 9 10-21-2012 07:37 PM
