Old 05-26-2019, 12:25 AM   #1
CAPSLOCK
CAPSLOCK's Avatar
Drives: Miata, 17' BRZ
Coilover install issue
hi guys, I'm having this really strange issue after installing my Fortune Auto 500 coilovers and LCAs. When I drive at anything more than 5mph the front end seems like its moving all over from side to side. Its almost like the car is a boat and waves are pushing it around. The rear seams tight like it should. This isnt my first coilover install and I've tightened everything to proper torque but i'm pretty much at loss here. Any ideas as to what I should be looking for?
CAPSLOCK is offline   Reply With Quote
Old 05-26-2019, 12:30 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Has the car been aligned since install ?
Old 05-26-2019, 02:01 AM   #3
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
2nd the alignment. Might have toe out or positive camber
EndlessAzure is offline   Reply With Quote
Old 05-26-2019, 07:28 AM   #4
cjd
cjd's Avatar
Drives: 2017 BRZ
What are the alignment specs? Negative camber tends to cause it to follow the road more... But I'm betting something else is amiss.
Old 05-26-2019, 09:21 AM   #5
CAPSLOCK
CAPSLOCK's Avatar
No alignment yet. I haven't had the nerve to drive out of my neighborhood. I mean can it be off so bad that it pulls just the front in a different direction then the car is moving? It really feels like I'm driving on ice or drifting in a straight line at 5mph
Old 05-26-2019, 02:23 PM   #6
strat61caster
strat61caster's Avatar
Yes, $60 toe plates and dial it in
Toe gets all kinds of screwy when you slap a bunch of camber onto the car, less so the bolting/unbolting process of the strut/damper, but you've got plates on now so you could've easily changed by a degree.
ineedyourdiddly
NoHaveMSG (05-26-2019)
Old 05-26-2019, 02:26 PM   #7
Chuckable
Drives: 2017 Toyota 86
If you want to get the toe close enough to rule out whether toe is the cause of the wonky feel, try this: Take a tape measure to the same spot on both front wheels at the front of the tires and the rear of the tires. Then, adjust toe to match and you’ll get ballpark 0 toe.
Chuckable is offline   Reply With Quote
Old 05-26-2019, 02:44 PM   #8
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Get an alignment please, have your vehicle towed if it's unsafe, this is the hidden cost associated with lowering your car unfortunately.
Old 05-27-2019, 08:49 PM   #9
CAPSLOCK
CAPSLOCK's Avatar
Thanks everyone, I can pretty much confirm its the toe in the rear. I'll report back after I get the alignment.
Old 05-27-2019, 09:27 PM   #10
maslin
Benz Tech
Drives: 2017 BRZ Premium
Front toe has to be multiple degrees out to really screw up the driving, being able to center the toe makes all the difference.
Rear toe is what gets you, thrust angle driving you straight in to the curb doesn’t feel good.
Hit a good dip in the road with even a slightly wonky thrust angle and you feel the whole car wiggle.
maslin is offline   Reply With Quote
Tein coilover install top but issue Slade Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-28-2018 09:13 PM
Coilover flexing issue slow n FuRiouS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-25-2016 02:42 PM
BC COILOVER ISSUE AZOOZ_95 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 12-09-2014 07:40 PM
BC Racing extreme drop Coilover Issue SmsAlSuwaidi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 06-11-2014 12:18 AM
Stance coilover issue tysoNgwaNg Northern California 18 04-29-2014 11:08 AM
