Old 12-16-2018, 06:19 AM   #1
csol
OEM BRZ fog light install issue
I bought the OEM fog light kit for my 2018 BRZ tS, since it doesn't come with fog lights:
https://parts.subaru.com/p/Subaru__/...4510CA150.html
installed the fog lights into place and there was a wiring harness taped up
I connected to that but I ran into an issue, the driverside dash doesn't have a cable that looks like this
as the instructions says
Instead somewhere higher up near the dash i found 1 with blue tape that looks like this:
guessing its the optional plug this and not what i'm looking for
does anyone have any clues as to which wires are used?
I got no idea it has to be something somewhere because there was definitely a wiring harness that I connected the lights to.
Any help is appreciated
csol is offline   Reply With Quote
Old 12-16-2018, 10:27 AM   #2
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
Looking at the installation instructions, Number nine looks like it says the taped up plug is on the cable running to the trunk switch. It's pretty easy to remove the end cover to the dash. Are you looking there? Your images indicate you are looking in the footwell.
fx1mark is offline   Reply With Quote
Old 12-16-2018, 01:36 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
you didn't mention it, but did you take off the large panel that has the trunk switch in it? the only way i could see the harness is with that panel dropped down. otherwise it's taped too high up to be visible from down below the panel.
Old 12-16-2018, 08:43 PM   #4
csol
Yeah I removed that whole thing, ill upload a picture soon.
But there is no wire there.
Old 12-16-2018, 09:57 PM   #5
fx1mark
fx1mark's Avatar
My only other suggestion is to note the colors of the wires where they connect to the light and try to find the same color wires under the dash.
Old 12-16-2018, 10:00 PM   #6
csol
Good sugguestion, I'm going to grab a multimeter and see if I can get some continuity going from one of the pins on the back of the fog light to the dash.
-edit-
green connector to the fog light has 2 wires
black and white/red
the black is the ground i tested with multimeter
and for those who wanted to see, this is what the driver side dash panel bit looks like, 2 cables for the trunk pop and dimmer but no cable tied in blue tape
2018, brz, fog, light, oem
Reverse issue after new clutch install mjanmohammad Issues | Warranty | Recalls / TSB 11 01-08-2018 01:29 AM
Valenti tail light signal light issue djdnz Cosmetic Modification (Interior/Exterior/Lighting) 70 12-03-2017 12:49 AM
weird issue after BPB & OFT install DAN_BRZ Engine, Exhaust, Transmission 10 06-10-2014 09:53 PM
Koni Install Issue WolfSongX Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 07-22-2013 09:17 PM
Pulley install issue Boxer-86 Engine, Exhaust, Transmission 9 10-21-2012 07:37 PM
