Old 10-20-2012, 11:32 PM   #1
Boxer-86
Boxer-86's Avatar
Drives: 2013 BRZ Limited
Pulley install issue
When installing a lightweight pulley, has anyone pulled out the crank snout? I put the Perrin pulley on and was pulling it off to set it down for a second and it pulled out what I imagine is the crank snout. I pushed it back in and finished the install, but I'm kind of scared to fire the car up. Has anyone has this happen?
2013 Raven FR-S - sold
2013 Satin White Pearl BRZ Limited - current
Boxer-86 is offline   Reply With Quote
Old 10-20-2012, 11:53 PM   #2
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Did you take any pics? Check out the DIY section and see if you see it in the factory shop manual online.
JimmyMac is offline   Reply With Quote
Old 10-20-2012, 11:58 PM   #3
JimmyMac
JimmyMac's Avatar
It's the pulley spacer.
Old 10-21-2012, 12:05 AM   #4
Boxer-86
Boxer-86's Avatar
Thank you sirs, just looked in the service manual and it is the pulley spacer. Guess I'm good to go!
Old 10-21-2012, 12:09 AM   #5
JimmyMac
JimmyMac's Avatar
Just make sure you didn't forget to put the o-ring back on!
Old 10-21-2012, 01:28 PM   #6
Boxer-86
Boxer-86's Avatar
I just took everything apart again and the o-ring is still in place and seated properly so hopefully everything is fine!
Old 10-21-2012, 06:03 PM   #7
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
I suppose that was a major "Oh Shit" moment. Thanks for posting up, I won't freak out if it happens to me.
celica73 is offline   Reply With Quote
Old 10-21-2012, 07:08 PM   #8
Boxer-86
Boxer-86's Avatar
It definitely was, I'll probably be rechecking the bolt with my torque wrench pretty frequently for a while. I triple checked the belt to ensure that it was seated properly on the pulleys and watched the crank pulley for any sign of wobble. Hopefully my Invidia catback install tomorrow night is much less eventful (should be)!
Old 10-21-2012, 07:11 PM   #9
JimmyMac
JimmyMac's Avatar
Only problem with the N1 is the silencers won't fit.
Old 10-21-2012, 07:37 PM   #10
Boxer-86
Boxer-86's Avatar
Not a problem, didn't plan on running them anyway.
Aftermarket Crank Pulley Install Enigmus DIY (Do-It-Yourself) Guides 305 02-04-2019 11:37 PM
Lightweight pulley wow Silverdub Engine, Exhaust, Transmission 240 01-23-2013 01:00 PM
Alternator pulley?? xpicer Scion FR-S / Toyota 86 GT86 General Forum 2 10-13-2012 08:54 AM
Camshaft Bolt Coming Loose After Perrin Pulley Install WhiteBRZ Engine, Exhaust, Transmission 25 09-20-2012 08:07 AM
pulley installed issue Sall Issues | Warranty | Recalls / TSB 31 08-14-2012 11:36 PM
