Drives: 2014 White FRS
Socket won't fit aftermarket lug well
Hi so I got some new aftermarket wheels and used my stock lugnuts. Problem is that the 3/4 wrench and 19mm socket does not fit the lug well of the wheel? It barely fits and is basically unable to turn. Any solutions to this??
Does a thin wall socket fix this issue and also is there a thin walled lug wrench? Thank you very much |
Wheels for Brains
Unlikely if the socket isnt fitting.
Might be time to get aftermarket lug nuts, which often use 17mm or spline/other designs that are a bit narrower |
Any recommendations on spline lugnuts that won't break the bank? Preferably black. Thanks
[insert cool phrase here]
Drives: BRZ Premium
If you need something quick till you buy some nice ones go to any auto parts store. You'll find something
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
Country Boy 4 Life
Gorilla
I LIKE TIRES! |
If you are using Harbor Freight they are thick walled. Snap-On is thin. They need to be thicker to be as strong.
Auto parts or ebay
20 steel nuts in various styles from $40. Don't buy cheap alloy. Or, spend lots because meh....drunk consuming on Ebay, the Project Mu stop the wheel from falling off
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
#8 | |
ProCrastinationConsultant
i will point and laugh. [ame]https://www.youtube.com/watch?v=IhI3DJdjSYQ[/ame]
Panda Trueno
Drives: No twin now.
#10 |
Drives: 2016 Ablaze FRS
Stock lugs don't seat properly on aftermarket wheels. The angle part is a ball style and not a 60 degree. I had a shop mount my wheels when I first got tires mounted and thats what they did. The wheels would shift as the lug was digging into the lug holes. Ended up stripping 5 studs and breaking 2 studs off when changing back to winters on stock rims.
#11 | |
Country Boy 4 Life
I LIKE TIRES! |
#12 |
Drives: 2014 GT86
As Leonardo wrote, OEM for twins are conical seat 60deg taper, which often referred as "tuner style lugnuts" (which is nice thing, as most aftermarket wheels have such kind of lugnut seat).
So if there for whatever reason ball seat lugnuts appeared in, exactly because aftermarket, not stock, wheels. IIRC ball style was common for VAG cars stock wheels. |
#13 |
Thats what I was told, that OEM was a different seat that 60 deg conicals. Thinking about it for a minute now, and the stocks were probably just too large to fit all the way down to the bottom of the aftermarket wheels.
#14 | |
Country Boy 4 Life
If I understand you correctly... WOW! Thhat would be a huge problem! Glad you are OK!
I LIKE TIRES! |
| OEM Rear Fog Light Socket | Slade | Electronics | Audio | NAV | Infotainment | 4 | 09-12-2019 02:02 PM |
| Wheel saver socket | Ashikabi | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 02-28-2016 04:46 PM |
| Which LED bulb/socket? | whip | DIY (Do-It-Yourself) Guides | 5 | 09-04-2014 02:44 AM |
| Socket Set | MrMista | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 10-28-2013 03:21 PM |
| Socket set and torque wrench | Ty89m | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 10 | 07-29-2013 12:46 AM |
